WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). There are daily reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
* Built-in better preamp (Same as Pre90...)
* A better way to mount a volume
* Built-in 12V trigger (I am using an LA90 power amp that supports this function)
* Remote control support
* Input device expandable
Guys what exactly is the difference between volume pot control and a ladder relay type thingy? Which is better and which does the A90d have? Also does the d90se çome with a remote?
Resistor ladder Relay gives superior channel balance at the lowest volumes (great for very sensitive IEMs) while traditional volume pot has infinite volume "steps". A90D has that resistor ladder relay while the A90 has the regular volume pot. The only time I see A90D being better than A90 is when you primarily use very sensitive IEMs like the one I have on my profile pic. Other than that, there should be no objective difference between the two amps
It's not the noise floor that causes the issue but channel imbalance rather. At low volume pot position i.e. 7-8 o'clock, A90 may exhibit channel imbalance (since very sensitive IEMs will be reasonably loud at those pot position even at low gain). A90D will have zero channel imbalance issues at any pot position. BTW, the only volume pot I've demoed with absolute zero channel imbalance at any volume position (pretty much closest to relay stepped attenuator performance without the step limitation) so far is the Alps RK50 4 gang pot implemented on Sony DMP Z1 and Blue Hawaii SE
Only if noise floor and distortion performance at 50 mV is very poor. A90D should NOT make any electrical noises or hiss with extremely sensitive IEMs.
* Oh. So can I use the a90d with both headphones and a powered speakers connected? If so how do I switch between them?
"Just select the 'Pre+HPA' mode with the remote control."
* What exactly is a 12V trigger?
"This is a terminal for interlocking power on/off between devices that support this terminal.
I'm using an LA90 power amp, which also supports 12V triggers. Two devices can be linked with this jack."
* What do you mean by input device expandable?
"Can connect more source devices using the EXT90 sold by Topping. It was a function supported by Pre90, but it is also supported in this A90D."
This is a review and detailed measurements of the updated version 2 of the RME ADI-2 FS DAC and headphone amplifier. It was kindly sent to me by the company. The cost us US $1,149. The ADI-2 looks very nice in black with a bright, super responsive display (doesn't come out as well in the...
The upgrading of a classic is an exciting but potentially confusing event. Everyone loves quality of life improvements, but no one likes having to hack through a jungle of specs. We’ve created this comparison chart to help you quickly and easily judge the differences between the classic A90 and...
This is totally wrong point of view. All features of the device should be usable withouth Remote. A90D has digital gain switch therefore it is easy to make it work by using volume knob/button. My child broke remote for topping D70s and it would be really bad if I've had to wait 3 weeks jut to be able to completely control my device. So this is a deal breaker for me.
Maybe Topping will enable this feature by some firmware update because if remote can do it, volume knob certanly can do it.
The difference in measurement is that the relay type generally has less channel imbalance.
TOPPING A90, Pre90 and SONY DMP-Z1 Channel imbalance vs. Volume position graph.
The amp I use - the topping LA90 does not support remote control. However, if you link the 12V trigger on the back of the device with other devices, you can turn the power on/off with the remote control of other devices.
I don't know yet whether it only supports power on/off, or if other functions can be operated with the remote control.
Perhaps we will know the result when the A90D arrives next week.
