AdamG
Do unto Others…
- Joined
- Jan 3, 2021
- Messages
- 5,406
- Likes
- 18,688
Hi Boss,This is a review and measurements of the Fosi Audio FH-05 five (5) channel analog headphone distribution amplifier. It was kindly sent to me by a member and costs US $49.
The package is extraordinarily nice given the price. Controls feel nice and having five outputs at once each with their own volume control is more than one could ask for. A tiny power supply powers the unit in the back. Note that I have tilted it up. Normally sits flat.
So it is clear what the device does, you feed it one analog stereo input using 3.5 mm jack, and then have five outputs of the same signal, each with their own volume trim. And then a master volume control.
Fosi Audio FH05 Headphone Distribution Amplifier Measurements
To have a realistic situation, I opted to drive the FH05 using a high-performance headphone amplifier, the Topping A90:
I then fed the output of A90 to FH05. Trying to get 4 volts out caused clipping so I backed off on the input to FH05 and adjusted the output to avoid clipping:
So we loose good bit of performance. Let's measure to see how much power we have at 300 and 32 ohm:
Sadly we don't have much power and what we have is in dongle adapter category, albeit a more powerful one.
Fosi nails the functionality and look/feel of the unit with FH05. Hard to imagine you can get anything close to that for $49. Alas, compromises had to be made to have not one, but five stereo headphone amplifiers here. Both in power and noise+distortion. I love to see Fosi build a higher end one with more powerful and lower distortion amplifiers, at least for one channel.
I can't recommend the Fosi Audio FH05 from overall performance point of view. That said, I could not produce a better product and sell it so cheap!
Just an FYI. I think the product name has a typo. Fosi’s webpage has it listed as the “PH05”. But the title is possibly incorrect in multiple locations Sir:
Fosi Audio PH05 5 Channel Headphone Amplifier
The SK02 employs a minimalist and stylish design language. Despite its small size, it boasts mighty features. It supports DSD256 and PCM 32bit/384kHz high-resolution decoding, along with 3.5mm single-ended and 4.4mm balanced headphone outputs.
fosiaudio.com
