Maybe one day I too will have mine.I've had my A30 Pro for about a month now and I LOVE it
No it'd be ridiculous, just a money sink. If you're into such things, Burson makes such amps...Imagine they made an amp with 10 swappable opamps....
So far it's excellent with my IEMs (Mest MKII, JVC FDX01, Legacy 4), dead silence at low and medium gain. Not even gonna try high .How is it with IEMs? Out of all the sub $500 amps it's the most interesting design in how it uses 10 opa1656 opamps which are excellent opamps.
None that I've come across, so far. Of course it is a new product, would be surprising.Any problems surfaced so far like with the L30?
I've received mine on TUE from Apos with the D30 Pro and have been enjoying the stack a lot with my DCA Aeon 2 Closed and Campfire Andromeda 2020.
Got the stack to replace my D90 and SMSL SP200 because I wanted a smaller footprint and a silver setup.
No issues so far.
I am planning to buy a SMSL SP200 (with the topping D30 pro dac)
what are your thoughts about the SP200 ? Would you reccomend it ? (or the SH-9 , a little improved version for just 20$ more)
the other ideas are : A30pro (but too new) , A50s (no balanced input) or ... I do not know, not too much ideas ...
what are the (sound) difference between A30 pro and Sp200 ?
thanks
Welcome Aboard @teoboss.I am planning to buy a SMSL SP200 (with the topping D30 pro dac)
thanks
Does anyone own a Topping a30 pro along with the Smsl sh-9? I want to know how they compared against each other.
I'm planning to get the smsl su-9 since I would be using Tidal to play my music (let me know if the d30 pro would be a better choice). I don't really care about the stack aesthetic, so mixing them up would be fine. The Smsl sh-9 is around $100 USD cheaper in my country, so I don't know if the extra cost would be worth it.
Planning to use it with a hifiman sundara(focal clear mg and hifiman arya in the future).
Thank you
Yes, I know that. I have been stuck with Tidal for a while as there are no other services available in my country (the only hope is Spotify hifi), so ideally, I would go with the Smsl su-9. I'm just wondering if the topping a30 pro is better than the smsl sh-9. If not, I'll just go with the Smsl stack.please note that D30pro is a very good dac but it is NOT mqa (while, as you now, smsl su9 is)
Massive paralleled RRO opa1656*10 + discrete flying supplies. All under a large heatsink. Opa564 was a good candidate but it's too similar to thx888 and running at the edge of the voltage can be some what non ideal.
Thank you
