I understand Topping isn't the only one doing it, SMSL for example is doing the same, it's not about the power of balance or SE, it's just simpler for the consumer to have a clear convention:
- If it has 4.4 or 4pin XLR output it's truly balanced
- If it has 2 3pin XLRs inputs it takes balanced in
- If it doesn't have preamp don't put a passthrough
- Else have 6.35 out and RCAs in, simpler, clearer, cheaper
Except there isn't a clear convention.
Tyll once invented double 3-pin XLR for balanced stereo.
Then 4 pin-XLR became a 'standard'
Also for portable they invented 2.5mm TRRS jacks
Sony launched an inbetween for 6.3 and 3.5 (4.4mm TRRRS Pentaconn) and were smart enough to include balanced and added extra ground so SE and Bal is an option.
For Stereo we are stuck with TRS jacks. These jacks are also used for mono balanced in & out connections, mics, line level, instruments.
For audio 3.5mm TRS became a standard until someone started adding mic+remote and added a ring but same shape. There are 2 different 'standards' in this where those idiots swapped ground and mic/remote connections.
There are even some rare folks who wanted to use 3.5mm TRRS for balanced. no success because of the more common mic/remotes.
Then we have the Pentaconn as well for SE.
So there isn't a convention.
All what matters is you can connect your headphones and they work properly. It really doesn't matter if it is balanced or has a single return wire.
The balanced cable will have the same benefits from a TRS out as XLR4 even when the signal is not balanced.
This amp does this, handy for those that want this. The more an amp has the more universal it can be used.
Behind the A30 it says PRO. Pros use TRS jacks, XLR, sometimes RCA (when only present) and the A30Pro takes them all and also home audio used XLR and RCA. The TRS jacks on the rear are clearly marked Balanced and L and R. Those that plug in their headphones haven't read the manual.
I would agree that the rear-outs should clearly state they are pass-throughs when it does not double as a pre-amp. That is confusing indeed.
