Please point to my mistake, I have no intention of undermining you or Topping, is the 4XLR out balanced like in the Magnius or A90 for example? are the inputs balanced like those as well?
The XLR inputs are balanced. If you just spent one minute you could get that information in searching in this thread. I was asked many many times about the related questions. And Amir of course did a great job at adding the notice.
The input pass through function is very well implemented in variety of devices. Even the previous old A30 no pro and the A50(no s). As well as the THX 789 and 887. It's just a little clarification that was needed.
The headphone output sockets are wired together. XLR and 4.4mm have a bit better distortion performance in the development. And it's just so much more convenient when you have have headphones with different cables. Also some headphones come with 4.4mm cable so they can use that. This is done on many amplifiers before like Neurochrome HP-1, Benchmark HPA4, SMSL SP200, SH9, TCA HPA-1. Amir only said outputs are SE, he didn't mention inputs in that second sentence.
JDS you mentioned does not have any balanced products in the first place. You then said A30pro is L30 with more redundant INs and OUTs. This blew my mind. And this is where I sense the disrespect.
On to the USB HDMI etc. They are the exact opposite of a good example. I couldn't believe anyone who remembers the specification for each version and naming would say such thing. Hence I said you didn't. It's not like plugging in A30pro will make your headphones blow up. It's all compatible. And you get the every last bit of juice of the amp. I don't see any issue. If any it's better than actually differential signaling where you could use the wrong adapter and potentially damage the amp. The power is as much as THX 789 in true balanced output. So this is absolutely fine in any way you look at it. And I was being very transparent about it since the first couple of page. That's why I told you at least to read through the thread a bit. You can't just look at a device and know how it works internally. It never worked that way.
