*Please let me know if this post is too demanding with several pictures, I'll fix it if it's bothersome.*
To be fair, it's not possible for the bass to be lagging, unprecise and inadequate if the frequency response and time domain response is that good. Assumptions must go towards the room/placement in such case.
My thoughts are that Kii is not really suitable for very loud spl with or without BXT. They run into audible distortion quite quickly in the upper bass/lower mids, perhaps due to undamped cabinet, lack of headroom in the driver or maybe just interference from the cardioide pattern;
I did experiment a bit with this distortion issue while I had the Kiis by trying subs crossed over at 200 hz and found that the audible strain at high spl diminished quite a bit, something easily audible if you try to switch on and off BXT during loud passages;
All in all I found that the Kiis are excellent speakers in a home-environment where you don't play at deafening volume levels, but they are too bright as standard with a few desibels too much in the top-end to my liking. Easily fixed by the on-board EQ, but usually the dealers don't fiddle with that - or even worse, actually increase the top end to create "more air", like Duet Audio did at some demos.
Constant directivity designs with a narrower directivity than normal speakers may perhaps be perceived as a little less airy per default?
I'd like to see a spinorama of Kii because I suspect there's some resonance around 3-4 khz that can be heard as ringing based on the smoothed measurement in the first picture in this post, but I didn't know enough about measurements at the time when I had them to find out for myself.
Regardless, they sound absolutely incredible once the top end is dialed down a bit in my opinion. Here's an in-room comparison of default Kii before room EQ vs my preferred tonal balance adjusted with Kii Control also before room EQ;
Comparing the Kii BXT with my preferred settings directly with Kef Blade, I preferred the Blade due to a more relaxing mid/high response, but the bass wasn't comparable at all. BXT just blew it completely out of the water below 250 hz, which was expected of course.
The subjective feeling in that department was that the Blade had a softer bass with far less snappy punch, and of course lacked the oomph in the deepest frequencies. Measured spl in the listening position was around 95 dB average with my phone app, far louder than I feel comfortable with. But very fun!
