I see. I saw some pictures and assumed they were yours.I don't use mixing desk, there's only small desk so my keyboard and mouse fit, not even meter wide
I’m actually curious how these class d amps have so much self noise. I’ll check tonight. Maybe he needs to send them back for inspection? I’ve done the process before it’s not that painful. They come out pretty easily.Sorry for my ignorance; but why did Genelec not engineer around this issue, would the (already high) price be even higher?
No please don’t do anything without their authorization. Just call the service team in your country. But if it’s both units then I would suspect a design issue.So I can open them without loosing warranty? That's good news as I could put the filter inside and forget about it. Anyway they forwarded my case to R&D team with all my measurements, recordings and presets and we'll see what's the conclusion
48dB is incredible. I cannot even imagine it and i’m in house far from any highways. The main issue here is other people’s hvac condensers.
As I’ve said before I can get to 53dB if my hvac is off and the neighbors’ are also off. I could quadruple the felt lined curtains to get lower but as soon my own hvac kicks in just the register airflow makes it 62-63dB.
I would literally have to pre cool the space. It’s crazy how hard it is for me to even get to 53dB. 48dB is just not in the cards for me. Unless I totally cover the front windows with 244 panels but I won’t do that. The option for natural light is important to me.
My condenser is 2 floors up but just the airflow is loud. I could have the upstairs vents trickle down but sound still carriesHVAC systems definitely add a lot of noise. I'm fortunate in my space that when the HVAC is not running the ambient SPL is 41-45dB. I just did very quick test with it running and it was 48-51. Big difference!
I have the accordion type but the airflow is just crazy. If I close the vents above me then it whistles. The air pressure is just too high.After posting my previous comment, I remembered that when our house was being built and I first heard the AC in my listening room, it was way too loud. Fortunately the vents feeding the room were easily accessible, so the builder had the HVAC contractor replace the rigid ductwork with flexible foil accordion style ductwork. That greatly reduced the noise produced by the airflow. But I still remember how loud it was before they did that, and there are one or two other places in the house where the airflow is somewhat loud from the rigid ductwork.
I don’t know if this applies to the W371A and if applicable to your situation (or maybe you are already doing it), but let me share my noise experience with the 8351B
By default (even) the 8351B’s was a tad noisier than I would desire. Yet I discovered that the noise comes from the analog input stage and ADC circuit. Feeding them digitally with AES/EBU AND switching off the analog inputs in GLM (from memory, I believe this is a must, else the analog input noise still got summed)
Ever since this configuration/setup, they are dead silent, even with my ear close to the tweeter.
If possible, try this, and switch off the analog input on GLM.
Yes, you can. The primary reason I did it was that the open inputs picked up noise and prevented the 8351B from going on Standby.Wait - you can disabl the analogue inputs? Do you recall where the setting for that is in GLM? I can't seem to find it. Thanks!
I think we are saying the same. In my setup for whatever reason it was on, picked up noise and made GLM think there is signal, therefor didn’t go on standby. Rightly configured it works well and there is no audible noise.that' only available when you specify analog or automatic input as a mai source (look on the left at input mode) , it's blanked out with digital in and turned off anyway
Yes I admit I haven't update for a while.right, maybe it was some older version of GLM software
Uncheck the “Analog Input” and select the channel (A or B) for your AES input. In my case, not only did it fix my standby issue, but the noise went down to inaudible. Asides from my previous Benchmark AHB2 setup, it’s the most silent system I’ve ever owned in this configuration.
Sorry for the confusion. I just tested the noise level again. Yes, if I shut all the doors and turn off all fans, I can hear a slight hiss it I come very close. But it’s low in level, and in my case, the environmental noise still dominates. I fully understand in a control room, you enjoy a dead silent room, and it is more audible.Thanks! I realized why I was having trouble understanding what you were referring to - like @cyjanopan, my analogue input was already disabled during the initial setup process, and checking the analogue input box now, it's blanked out/disabled and cannot be toggled.
Even with analogue input disabled, I still can hear self-noise from my 8351s. But perhaps it's lower level than what you were experiencing with your analogue inputs enabled? I just did a slightly more controlled test than I've done before, and to hear the noise of mine, I have to get within 3 feet of them, bend down to put my head level with the drivers, and turn my head sideways so my ear is directly facing the drivers. When air is flowing through the HVAC vent in my room, then I have to get within a few inches of the speakers to discern their self-noise. But mine have clear self-noise if I put my ear right next to the tweeter as to have described.
Admittedly the Kii audios are the most silent monitors I can think of. But no surprise with its legendary designer
The first image is my environmental noise. Second in front of the tweeter few inches away.
How/where did you get those genelec stands in white?Sorry for the confusion. I just tested the noise level again. Yes, if I shut all the doors and turn off all fans, I can hear a slight hiss it I come very close. But it’s low in level, and in my case, the environmental noise still dominates. I fully understand in a control room, you enjoy a dead silent room, and it is more audible.
Custom order from K&M by the Chinese Genelec distributor. (I live in China)How/where did you get those genelec stands in white?
