5dBA SPL at 1m becomes 0dBA at 1.8m.
15dBA SPL at 1m becomes 0dBA at 5.6m. The calculation I did, the noise specs Genelec provides online. I've never paid attention to them before since no one has ever complained. They are right there though, openly disclosed. It is a failure on our side not to appreciate or discuss them.
@cyjanopan You won't be able to fix noise with a digital filter. The speakers are functioning properly.
This is the W371A bandwidth. Don't set a filter that will mess with the upper range or you will ruin the integration with the 8351B.
The best thing all of us can do is contact Genelec and tell them 15dBA noise at 1m ruins the W371A product for many small spaces and people.
@Thomas Lund @Ilkka Rissanen
Like I said above, a digital filter will do nothing. This is an analog problem. Perhaps you may be able to lower input gain inside GLM. Using volume control further down the signal chain will do nothing.
