Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,272
- Likes
- 5,521
From what price would you say speakers hit the point of diminishing returns?
I got the R7... This tower can go insanely loud and much deeper than my last speaker (r300)there isn't a precise point really.
To play loud you need multiple woofers which drives up cost.
To have a design with no audible cabinet resonances (buzzing/rattling) when playing loud it will also take $$$ for research and development.
But for me for bookshelves it would be KEF R3 (2000$ a pair) or the equivalent in Genelecs lineup, as it has no audible harmonic distortion at any level near field and excellent radiation due to coaxial design.
For floor standers / far field it would be Revel F208 (5000$ a pair).
The towers can go very loud without show any distortion, is not even a comparable to my previous bookshelfthis is not really a metric imo, the important question is whether it bothers you at these insanely loud levels (distortion).
What do you mean by 55 and 85?The towers can go very loud without show any distortion, is not even a comparable to my previous bookshelf
In my pre amp the r300 at 55 the drivers show itself unhappy, but the R7 can go to 85..i dont know if that was the limit but wtffff was too much for my entire house...
The volumen in my pre amp 0-99 3vrms - > power amp is purifi eigentakt eval1What do you mean by 55 and 85?
Kids these days don’t know how lucky they are, back in the day speakers could only go up to 11.What do you mean by 55 and 85?
Is 80% of their performance measured on a linear or log scale? I get so confused with audio components...I've often wondered about this. If the Revel Salon, the Genelec 8351a/W371 are considered SOTA then at what price point could you get 80% of their performance? I realize "performance" would have to be defined and quantified in a meaningful way.
My (possibly unpopular) opinion is that in audio the returns diminish very quickly. Every other speaker I bought or heard after e.g. the JBL LSR305 (~300$/pair) has been a relatively small SQ increment vs the huge SQ jump of going from some random BT, multimedia or TV loudspeaker to the 305s.From what price would you say speakers hit the point of diminishing returns?
-6 dB of the price gives you -3dB of the performance (both as power values)Is 80% of their performance measured on a linear or log scale? I get so confused with audio components...
Even if you were to define your requirements, how would one plot the extent to which the requirements are met vs. price?
I can't even define my requirements. For example, would I prefer a pair of Revel F208's in stereo to nine ELAC DBR-62s using Auro 3D upmixing? I have no idea.
