- Joined
- Mar 17, 2020
- Messages
- 1,071
- Likes
- 4,547
He did not recomend them, and that is his choice. Yes he is clear about that. And yes I do not think that detracts anything from subjectivity except to say that at least this subjectivists is honest even when it hurts his subjectivity itself as a concept.
I just finished modding the Ultra's to see if I could get at what was bothering Amir. There are two issues that may have contributed to the perceived brightness. One, which doesn't show up on Amir's measurements due, I think, to the protective device he uses on the mic, is that the tweeter takes off like a rocket above about 14 kHz. I don't think I can hear that, but maybe Amir's ears are less battered than mine. The other is that SVS kind of fudged the tweeter circuit. There is a big hump in the raw tweeter response at the low end (which is very common in baffles this size), and the crossover doesn't attempt to achieve an accurate 4th order acoustic roll-off. The tweeter response instead levels off on the way down, but still sums fairly flat with the woofer. Maybe it's the greater-than-normal tweeter contribution in the 2-3 kHz range that Amir is picking up on.
Frankly, I didn't find the Ultra's particularly bright. I was just bothered by a lack of focus in the mid-treble due to the U-shaped response and perhaps the less-than-precise roll-offs. Here are the before and after on-axis plots. I deliberately ramped the tweeter response down a little just to avoid any remaining brightness that people might hear.
