Disclaimer: We're a subwoofer (and loudspeaker) manufacturer, focusing primarily on music/hifi customers, so take this with however many grains of salt you wish:
For music reproduction the requirements of low end output is typically less than for movies, which means subwoofers can be made smaller, while the requirements for quality and linearity is higher. This means different tradeoffs than a cinema oriented subwoofer.
A subwoofer created for music would typically benefit from a more even frequency response, lower distortion within it's operating range and SPL capabilities, and depending on your use case, a wider frequency response. It would also preferrably be sealed, as having a ported subwoofer with very low fs and zero port noise is difficult to do in a smaller cabinet.
Some subwoofers also exhibit relatively high THD long before they reach their CEA2010 limits, making the CEA2010 test insufficient to identify overall distortion at moderate listening levels.
The audibility of distortion in low frequencies are debatable, but as in any other part of this hobby, many want as high quality as possible in all parts of their listening chain. Subwoofers are no different than loudspeakers, amps, sources or anything else in this regard.
