If your fronts go down to 20 Hz effortlessly and you mostly need one sweet spot, no.In a home cinema system with large fronts, do one need a subwoofer?
Today in theory my fronts play deeper than my sub, should i let i go?
Thanks
Heco Dreiklang and my old Velodyne SPL1200Ultra.What speakers do you have?
Thanks, i think the fronts would be able to handle the LFE. If fronts are relived of this they ofcourse could do their thing better. My question is has any of you guys done this, removed the sub and have any comments regarding doing so.If your fronts go down to 20 Hz effortlessly and you mostly need one sweet spot, no.
But in practice, there are very few speakers that produce 20 Hz at high SPL cleanly. And if you need smooth bass response throughout a larger area (big sofa, multiple rows of seats etc.) you need subs.
Subs are super in helping bass performance. My Q is if any of you guys have tried doing without the sub and could share that experiance.What speakers were you thinking of?
Do they play down to 10hz? Because subs can. Plus you can position multiple subs (say in corners or in mid-way of walls) for best in-room response, while towers are seldom in the best place for best bass.
Not measured yet and realy not tried this out, will do so this "free" weekend.Wow, those really are full range. 19Hz extension with 98dB efficiency. I would say you have a full range sound in those. However, the best spot for imaging is likely a bad spot for smooth bass. Smooth bass usually requires multiple subs spread around the room, but sometimes you can get lucky. Have you measured yet?
I tried running my 3-way PSB towers (-3db point was at 30hz) at full range briefly. But once my AVR abruptly shut down during a movie, I got scared for my amplifier failing and bought a subwoofer the next day.Subs are super in helping bass performance. My Q is if any of you guys have tried doing without the sub and could share that experiance.
I have and do not watch moviesor litsen to music very "loud".If you want to play reference(115dB at or below 20hz required), subs may still be needed. At -10dB it's probably fine. I'm assuming you have an actual surround system.
Bass levels are often lower in stereo mixes than in the full Atmos/DTS ones, so in that case it may not matter.
Thanks, yes that is the thing for me. It will be at best 1 sub here soo i am not sure i should have one at all.Wow, those really are full range. 19Hz extension with 98dB efficiency. I would say you have a full range sound in those. However, the best spot for imaging is likely a bad spot for smooth bass. Smooth bass usually requires multiple subs spread around the room, but sometimes you can get lucky. Have you measured yet?
