Strawberry. Open Source cross platform music player
Joramun
Hi all,
Thought I'd share this Open Source cross platform music player.
Found it while looking for a foobar alternative.
I'm using the Windows version and have pretty good experience so far.
It has support for Subsonic, Tidal and Qobuz too.
Web page here: https://www.strawberrymusicplayer.org/
Svensson
I used this on my Linux machine a while back. Great app overall (basically it's Clementine, improved). Killer and essential feature is the direct output to a USB DAC. Have not used for a years or so, and now back to Debian, so will give it another try, just for fun.
Rottmannash
Nashville
Just downloaded it-seems great for radios and local files but appears problematic for Qobuz. Any idea how I can get the multiple entries required to use Qobuz on Strawberry?
Rottmannash
Nashville
A question: Can Strawberry bypass the Windows mixer much like Audirvana? It appears every file I play is at 96 Khz whether is is mp3 of flac or DSD.
J
Joramun
Go to Settings > Backend and you can set the Output and Device there. See if that helps.
Mine shows whatever the file supports. See below
J
Joramun
I haven't played around with Qobuz or Tidal.
They have forums for support if you want to ask them directly:
Rednaxela
NL
Nice.
Wished it would look a bit better though.
Rottmannash
Nashville
My DAC shows 96 no matter the file type.
J
Joramun
Check your Windows settings.
Ensure that you set the DAC to your preferred quality. See screenshot below
Rottmannash
Nashville
I was hoping to bypass the mixer, much like Aurdirvana does so the files play at their native rate.
