Strawberry. Open Source cross platform music player
Joramun
Hi all,
Thought I'd share this Open Source cross platform music player.
Found it while looking for a foobar alternative.
I'm using the Windows version and have pretty good experience so far.
It has support for Subsonic, Tidal and Qobuz too.
Web page here: https://www.strawberrymusicplayer.org/
I used this on my Linux machine a while back. Great app overall (basically it's Clementine, improved). Killer and essential feature is the direct output to a USB DAC. Have not used for a years or so, and now back to Debian, so will give it another try, just for fun.
Just downloaded it-seems great for radios and local files but appears problematic for Qobuz. Any idea how I can get the multiple entries required to use Qobuz on Strawberry?
A question: Can Strawberry bypass the Windows mixer much like Audirvana? It appears every file I play is at 96 Khz whether is is mp3 of flac or DSD.
Go to Settings > Backend and you can set the Output and Device there. See if that helps.
Mine shows whatever the file supports. See below
I haven't played around with Qobuz or Tidal.
They have forums for support if you want to ask them directly:
My DAC shows 96 no matter the file type.
Check your Windows settings.
Ensure that you set the DAC to your preferred quality. See screenshot below
I was hoping to bypass the mixer, much like Aurdirvana does so the files play at their native rate.
Mixer bypassing works well for me if the right output is selected.
Has anyone managed to play music stored on a NAS with Strawberry ? I thought life would be simple, just put all music on NAS and then, like I selected my music folder in my computer as a library for strawberry, that I would just have to do the same with the music folder stored away in the NAS. But I can't find how. Because the (synology) Nas itself has its own music player, but I haven't found, if possible, how to select my dac as a direct output. Anyone passed this hurdle yet ?
