That's the Loxjie D50. D5 is 9038pro based.
Opps! I made a mistake.
The same is true for the SU-9 and Sabaj A20d.
Is it difficult to solve the M500 problem? The M500 also has a problem with XLR output pop noise.
If you connect the XLR output directly to the power amplifier and turn on / off the power of the M500, you will be hit by a large pop noise.
How is the progress of the D30Pro issue?
I bought the D30 Pro right after its launch and immediately noticed a PCM 384kHz noise problem and reported it to Topping. Is this problem likely to be resolved soon?
The D30 Pro also has the problem that when switching to a song with a different bit rate, the beginning of the song disappears due to the fade-in operation.
