No it doesn't. They are looking whether they can get it to work with the existing hardware when I asked StormAudio support the same questionThanks. Does the LAN input accept multichannel from Roon?
It is a modular design and any single board can be repaired or replaced. I upgraded my MK1 to a MK1.5 which included four new FPGA boards (not DSP chips) and a new decoder board. I also upgraded its HDMI board and have added AVB output. All US repair or upgrade is done in California.
Your assumption is correct. But implementations vary. Sometimes the position of the volume control makes no difference. Other times the firmware switches gain stages and produces different results based on position of the volume control. Here is an example:
I don't recall now why I did not run the storm at different volume levels. I ran the tests a few days ago and already forgot.
What do these volume levels translate to in terms of a known reference i.e. reference level? (I *think* 80 is reference level(much louder than most listen)? so 90 would show performance for those that listen at 10 dB above reference level?)Your assumption is correct. But implementations vary. Sometimes the position of the volume control makes no difference. Other times the firmware switches gain stages and produces different results based on position of the volume control. Here is an example:
Copy-paste from the 3rd paragraph:
"As is my common practice, when manufacturers send me something and I find problems, I provide feedback to them prior to publication".
Amir has stated that is the company sends it to him, he gives them the privilege of checking the measurements beforehand, and to make necessary changes if they see fit. Any changes would thus be in a software fix, so existing owners will benefit.
This depends on your speaker sensitivity, listening distance, and your amp power. You will probably need to measure it rather than calculate because specs vary.What do these volume levels translate to in terms of a known reference i.e. reference level? (I *think* 80 is reference level(much louder than most listen)? so 90 would show performance for those that listen at 10 dB above reference level?)
That's correct. It is a carrot for companies to send products in, rather than waiting for their customers to do so. I know there are pros and cons to this but that is my current strategy.
Oh my... This backplate looks so cheap for 15k.View attachment 122679
At last, close to decent performance for an AV processor! Software also seems to be next-level.
This so called “hygiene” may easily result in intermodulations in the next amplifier, as the ultrasonic components are equal or well below 100kHz and thus below the action of the usual input RC filter. This is a bad feature and should not be overlooked by an experienced test person.
So, the results may or may not reflect real life SINAD values. But I assume the regular THD+N, SINAD is always done with 0dBFS signal and with device's master volume adjusted to get 2V or 4V?
So it seems that StormAudio will support Roon/MCH soon (and as does Trinnov now).ROON kommer att spela multikanal på Storm, datumet kunde inte nämnas av stödet ännu, dessutom kommer det att finnas möjlighet att fungera, till exempel för att hoppa i en spellista.
But in that case, wouldn't such components show up in the FFT and be included in the SINAD measured, if they are in fact within the audible band? THD+N/SINAD measurements only notch out the fundamental of the test signal right?
How much would you charge for me to get you as my personal always available projectionist?$15 grand waste of money. If it can't do what I did when projectionist and react fast with video mode settings and sound formats then it is slower than a snail for $15 grand. I would wait 4 years for it to be on ebay for $100.00
FOC. I once enjoyed doing it. But never mind the inflation that is just a word to make people crack up. I don't know, $5.00 per hour and that is cheap.How much would you charge for me to get you as my personal always available projectionist?
Would you not have to start measuring amplifiers to determine immunity from out of band noise to know?
That same is true of noise or signal in HD Audio above 20 kHz. Some speakers may not be bothered but others may be.
The HD Audio "Keys" test is a good example. Credible folks have passed ABX tests.
Clearly, these people do not hear above 20kHz so something is happening in the audible range.
Bias comes in when we assume that different is showing efficacy.
It may show that their system was modulating what should in inaudible to become audible.
That does not sound good to me
IMO, design hygiene and out of band anomalies are to be avoided and should not the present in very expensive products.
- Rich
That's correct. The level of volume control is indicated on the dashboard (-7.1 dB here).So, the results may or may not reflect real life SINAD values. But I assume the regular THD+N, SINAD is always done with 0dBFS signal and with device's master volume adjusted to get 2V or 4V?
Yeh, similar problem exists with measuring integrated amplifiers as to what volume control position to use vs input level.About implementations: for example the Monoprice HTP-1 allows to separately adjust max. output voltage (reducing fixed gain after the analog volume control) but it's master volume control also adjusts digital headroom in addition to analog gain. But it adjusts digital headroom only to -11dB mv scale and below that it uses just analog gain. To fully measure such thing would take a long time.
