Does anybody else see the irony in how the post turned from the subjective bashing of Amir to a PhD dissertation on capacitors.
Immediate replacement is optimal if the equipment has not been on for approximately 2 years, since excessive leakage current from dielectric breakdown can be detrimental to connected components.... and how was the DCR of all of those caps relative to new ones?
Sometimes it matters, sometimes it doesn't -- depending upon why the capacitor is in the circuit.
Oh, just to be clear, I am no fan of shotgunning capacitor changes in vintage hardware (a la the quintessential AK recapper types). Seems silly to me, too. And the tolerance on electrolytics (especially 40 to 50 years ago, and especially fairly large value electrolytics as found in power supplies) was quite broad.
In resonant circuits, the exact values for a capacitor tend to be more important, methinks.
How do you go about measuring whether DCR is out of spec or was it equivalent series resistance?DCR is critical in applications where ripple or other AC currents are significant, as an example, switch-mode power supply in and out bypassing caps. In small signal analog circuits applications, such as coupling caps, where surrounding circuit resistances are huge compared with the fraction of an ohm or so DCR of the cap, the DCR is completely insignificant and can be ignored. The only time to become concerned about DCR is if it is abnormally high and out of spec for the cap. That could indicate a problem with the cap.
I recalled that vintage analog equipment is still rather worthwhile, compared with unabashed rip-off amplifiers that are reviewed in Stereophile.Does anybody else see the irony in how the post turned from the subjective bashing of Amir to a PhD dissertation on capacitors.
Whoops! Freudian slip, I suppose. Yes, ESR.How do you go about measuring whether DCR is out of spec or was it equivalent series resistance?
An AC test signal is used for dissipation factor, DCR is what a multimeter would do that shows an open circuit or short circuit.Capacitor manufacturers usually specify a maximum DCR for their products. To measure DCR, it takes a cap meter that vectorially resolves the reactive component (C) from the resistive one (R), usually by way of reporting dissipation factor as a stand in for R.
The only irony I see is you didn't understand the importance of capacitors.Does anybody else see the irony in how the post turned from the subjective bashing of Amir to a PhD dissertation on capacitors.
John Atkinson and Larry Archibald started the new Stereophile with the express decision - No pro gear. The Genelec home models are the ones that Stereophile reviews and very positively so. Of course, Genelec has more of a presence now with audiophiles undoubtedly due to ASR.Anyone here find it more than just a bit ironic that Stereophile has all of a sudden started to review Topping and Genelec gear ???
Not sure how well that translates to the ex-US audience here (although they know futbol, of course)it's there to play fuh baw!
A link to the article that the abstract comes from: https://keith-snook.info/wireless-world-magazine/Wireless-World-1952/Amplifiers-and-Superlatives.pdf10 years before Stereophile even existed, there was a decent article about sound quality...
D. T. N. WILLIAMSON and P. J. WALKER. Amplifiers and Superlatives: An Examination of American Claims for Improving Linearity and Efficiency. WIRELESS WORLD, SEPTEMBER 1952.
"Recent articles, particularly in the United States, have shown that some confusion of thought exists about the "goodness" of an amplifier for reproducing sound. This has been accompanied by a debasement of the terms used to describe the properties of an amplifier; words that have a precise meaning when standing alone become meaningless when qualified by superlatives. This article, which starts with a discussion of what constitutes a good amplifier, attempts to clear up some misconceptions and generally to clarify the position."
Walker was an audio genius..10 years before Stereophile even existed, there was a decent article about sound quality...
0.1% THD, readily achievable in 1944. Just makes you appreciate what a mess some of the tube amps are that have been tested hereA link to the article that the abstract comes from: https://keith-snook.info/wireless-world-magazine/Wireless-World-1952/Amplifiers-and-Superlatives.pdf
Hmm. If .1% is low enough, why are we obsessing about whether a DAC or amp has .01 or .00001?
