And who tells you that the wider image is the more "correct" one?
And who guarantees you that other listeners also perceive it like that?
And who guarantees you that some of your speakers have not worse channel matching which could create a wider more diffuse imaging?
And what about directivity, edge diffraction and interaction with close boundaries which play by far the biggest role on the size and precision of imaging?
this can hear with my speaker records and compare with the original in headphones. the kali record stereo width is much smaller. you need look at the latest examples. the first examples are record with stereo bar.
here begin this records
It is a test of 3 speakers record with 2 MTM MEMS microphones on a stereo Microphone Bar. Part 1(the first) of the compare.mp3 piece is the original. Part 2 Part 3 Part 4 are the recorded speakers i have test. I have EQ so all speakers sound in frequency near same. Is it for you clear hearable...
www.audiosciencereview.com
The forum software have a bug it post not the text that is in the post i link. in the post i link is this text
between original(1b) and the 3 b you hear stereo width diffrence ?. I have no UAD and can not test
Now have upload new records. First i record left channel then on a second play the right channel. then i mix the 2 mono records in DAW to stereo. this avoid crossfeed from left to right speaker due to microphones and the better speaker do not loss so much stereo separation as the stereo record. all records sound now in generel more near as the previous records with 2 microphones on microphone bar
i named it 5 b and 6 b. is it now better hear which record have stereo width or stereo separation smallest to original ?
Edit: there are more speaker records i do first record left channel then right channel.
The LP6 have a 6,5 inch speaker. the step resonse show it is very slow and i hear before i notice that it is the step response that transient sound worse and muddy and it have less stereo width. But test with other peoples show that there are people that did not hear less or more stereo width...
it have a 3,5 inch small bass and mid so step response is very good and i hear lots more realistic stereo wide as on Kali 6.5 . It have a hifi FR with the hifi magic gap at 300- 700 hz. the gap at 10 khz have both speakers so it seem not a defect of the speaker or wrong measure. I verify many...
The mtm have god step response and stereo width. in my room you can see the measure result too and look good. the bass range is enough when you hear not louder as 80 db. a little problem on this speaker i think the port noise. on some songs when hear louder as 80 db then port noise can hear. I...
I record first left channel then right channel with same microphone position and same speaker. So in Fact. this record way have no crossfeed and a diffrence in quality between the two speaker is also avoid.
the room reverb have also no noticable influence about stereo width. i record my room impulse, and can play the original over convolution reverb with my room impulse on headphone and it get no stereo width loss.
You give the impression that you are fixed just on one parameter which you want to force it to fit your individual perception and explanation while ignoring all others which are known to play a significant role on the phenomenon you are trying to investigate. A bit like a policeman with a radar gun at the road close to the Ferrari factory who comes to the conclusion that the reason why some cars are are faster than the rest is their red paintwork...
is it not clear because the thread title contain text "step response is a important part". I never have written that it is more important as FR or phase or something else. I only written that it is a important part and this mean that it is not bad that it is show in speaker tests. or do you think it is bad and should not show ?
this have low bass -3 db 52 hz they write. have very short step response.
www.stereo.de
