Speaker upgrade - options and suggestions
even though not high end by any means
Audioholics reviewed both Klipsh RP-8000F mk I and mk II
Measurements are really good
Enjoy...
Whatever speakers you get, add room correction to your budget.
You could connect a Minidsp DDRc-24 between your Pre-out Main-in on the amp and run everything through Dirac live.
It’s amazing the peaks and troughs you will clear up below 500hz in just about every living room.
You might even find you don’t need a speaker upgrade…although Dirac+new speakers is always going to be more fun!
Yes, that's always a good idea. I don't want to spend around 500 Euros to get a minidsp audioprocessor which has Dirac on it (I'd rather have the amount available for the speakers), so I purchased the UMIK-1 to do some measurements and room correction.
