- Joined
- Feb 23, 2016
- Messages
- 20,771
- Likes
- 37,636
600 ohm output impedance.
Now they just need a good headphone amp companion piece. $40k should do it.
So, basically, the entire DAC is jammed on the tiny board that I circled in blue & everything else is for a bare-bones tube preamp w/ some extra transformers? What here is worth so much money? The chassis isn't even copper. The wiring isn't even neat!
Seriously, what the heck kind of loads do they think they're handling to require so many transformers of that heft & size? Honestly, any kind of theoretical(?) improvements they'd gain from having transformers for different stages of the amp will be lost due to inductive coupling from how close the transformers are to each other (even though they offset & rotated some of them somewhat). For this price tag, at least put them in a separate chassis...
$43K, you can have a 3 series BMW for that, or a Jeep Wrangler with some options.
Hum adds that organic touch. A basso profundo singing along to every piece.any kind of theoretical(?) improvements they'd gain from having transformers for different stages of the amp will be lost due to inductive coupling from how close the transformers are to each other (even though they offset & rotated some of them somewhat). For this price tag, at least put them in a separate chassis...
It's so bad the obscenity filter let you say that.What a crock of shit
I especially like the chip mounted on an SMD to breadboard adapter. Following in the footsteps of Ciunas, what could possibly go wrong?
Its likely because these are single layer PCBs like ye' olde days. Either Audio Note doesn't want/know how to design a low-noise two/four layer PCB with fine pitch traces...or maybe they think its too expensive!
P.T. Barnum underestimated by 18 dB.Pard me my language; there's a sucker born every second.
These are for the people that have all 9 of their garage spaces filled with cars already.
I can't blame companies for going after this market. If you sell $100 DACs how many do you have to sell to make the same profit they are making on one of these?
Oh, I get it. "Veils" is just another word for power supply bypass caps.That's the convenient upgrade slot - just in case you want even more veil lifting at a later stage.
Are pictures o.k.?It's so bad the obscenity filter let you say that.
Ahem! Did you not receive the memo? Transformers are now the audiophile equivalent of cheap Chinese manufacturers filling the void of their hollow junkyard-destined products with reject nuts and bolts to add heft since everybody knows that WEIGHT = QUALITY!!!
