restorer-john
It does indeed get warm just sitting there.
A nice winter headphone amplifier.
Their much cheaper SMSL SH-9 features relay based volume control and has lower/same noise levels.Expense, noise and long term reliability.
Expense, noise and long term reliability. They made the right choice in my opinion- as long as the pot is a good one. A decent pot lasts 30-40 years. If you'd replaced as many small signal relays as I have, you'd steer clear of relay based volume controls too.
In terms of reliability, what happens when a relay fails (specifically for volume control) out of interest?
Does it just mean you have bigger jumps in volume as each relay fails ?
Quick question if you don't mind: what happens when the relays fail? I mean they don't all fail at the same time. Is just one part of the volume control not usable or does the whole array need to be changed? Thanks!
Yeah, A70 Pro is a better option
Thanks for amirm's review
Maybe it's very expensive, but at least it's ugly as hell. It would sit nicely in the home of a lonely guy who is collecting ceramic dolls and brass ring bells.Only a mother could love that face…
What would you consider a better alternative for perfect channel balance thenIt depends how the relay ladder is arranged, but noise, intermittent signal etc. can be a problem. Consider headphone output signal level really is chickenfeed in terms of current. Contacts oxidise over the years and there simply isn't enough current to 'burn' through the oxide layers, resulting in poor contact.
Sure, if the relays are super high quality, inert gas-filled and sealed, silver/gold contacts, maybe you'll get a good life out of them. But I doubt they are anything more than poverty spec 'sealed' 'small signal' relays.
A pile of relays is a pile of reliability issues and a pile of expense. They are moving electromechanical parts with moving contacts and you need quite a few in a balanced 2 channel unit if you want fine volume control.
A relay driven volume is not a sign of a quality headphone amplifier. To me, it's just a box ticking exercise to sell to headfi type guys.
good morning amirmReserved for specs.
I think for a "high end" product, a good pot that works as well as this one, adds to the value of the product. I have had several SMSL and Topping DAC's with volume controls and while they "work" the "feel" is not even close to the same as a good analog pot. While a digital volume control with relays is technically superior and cheaper and easier to make the feel of good analog pot can not be beat. Good analog costs more than perfect digital so in this case it looks like you are getting something for the extra cost.just regular pot, opportunity lost.
This is very far from an "average pot". A well executed analog pot is better in every way, it is just hard and expensive to execute well.you need something better than an average pot and a couple gain levels.
Thanks for the testing Amir.FYI company claims that there are 99 opamps used in the P2!
But how am I supposed to roll 99 opamps? I may have to host an opamp rolling get together...
