Yay! It worked!
That 'sleep' setting is presumably a default intended for mobile devices (to save a watt, or fraction of) and it's pretty silly left set for a desk-top unit. I wonder how many returns SMSL and others have had to deal with thanks to this?
ETA>> - congrats on being able to fix four of the little beasties.
Yes, it plays DSD fine, that was one of the reasons I didn't want to use SPDIF, even if it stopped the noises. No indicator for that, bitrate or anything else, it's a stripped-down DAC and that's actually one of the reasons I bought it. If SMSL (or someone else) made a similarly hair-shirt (and commensurately cheap) DAC/preamp with no display I'd have bought one - if anything's going to fail sooner rather than later it'll be a display panel. ETA >> That said, I'd want a basic remote for volume control and I guess that mandates some kind of display - was considering an Sanskrit, but couldn't ascertain how reliable they are.Ordered, has anyone played DSD files? I want to know if it has any led indicator that it is playing DSD. In the manual it shows only led color change when MQA file being played.
Even though I mostly change the volume on the amp, I still want a remote for changing the source or turning it on or off. But for this price (52 usd after "618" event discount + voucher), I think it'd be a bargain.Yes, it plays DSD fine, that was one of the reasons I didn't want to use SPDIF, even if it stopped the noises. No indicator for that, bitrate or anything else, it's a stripped-down DAC and that's actually one of the reasons I bought it. If SMSL (or someone else) made a similarly hair-shirt (and commensurately cheap) DAC/preamp with no display I'd have bought one - if anything's going to fail sooner rather than later it'll be a display panel. ETA >> That said, I'd want a basic remote for volume control and I guess that mandates some kind of display - was considering an Sanskrit, but couldn't ascertain how reliable they are.
You've prompted me to pin it to the taskbar (along with Equaliser APO and its 'configurator'), really useful for instantly checking what sample-rate I've set Windows sound to when using DirectSound.You see what's sent to device it in ASIO Control Panel. My picture is for E50, but it looks for every XMOS the same.
22579200 / 44100 = 512 ... DSD512
You can have Control Panel permanently open. It updates in real time.
Are there apps/plugin that could be pinned to taskbar to show which bitrate being played? That would be very convenient.You've prompted me to pin it to the taskbar (along with Equaliser APO and its 'configurator'), really useful for instantly checking what sample-rate I've set Windows sound to when using DirectSound.
I'm new to audio stuff and I'm currently using Fosi Audio Q4 on my PC and looking to upgrade my setup and audio listening.
The SMSL SU-1 is affordable that is why I'm considering buying this but I'm not sure what headphones amp to partner up with this DAC.
Could someone recommend me an affordable amp for this?
Also, is Topping DX1 or Topping DX3 Pro+ a better option than a stack DAC and AMP than I've mentioned?
Currently using Epos H6Pro, Aria Snow, and Crinacle Zero.
I appreciate any feedback.
Sabaj A10h, $75I'm new to audio stuff and I'm currently using Fosi Audio Q4 on my PC and looking to upgrade my setup and audio listening.
www.audiosciencereview.com
Not in an easy to reach place. I tried some old Mac Docking hubs and the kluge did not work.Why use the Splitter? If it is only sometimes, you just pull out the USB-C from the Charger and stick it in your Computer?
Just a longer USB-C cable then, to a „better to reach“-spot?Not in an easy to reach place.
