SMSL DA-9 + RME ADI2 DAC fs connected via XLR. RCA outputs connected to Tube amp.
I encountered immense white noise. I found that very odd as there was no noise with the SMSL DA-8s in the same exact position and cables.
I had replaced the factory thermal grease with HY883, a pretty highly rated grease intended for CPUs which left the DA8s running cooler than the HDF audio rack.
So just now, I removed all of the factory thermal grease/paste from my DA-9. It has yet to cure, but the white noise is gone. I can now use the XLR's connected to the RME DAC, and the RCA outputs connected to my valve amplifier. Noise is gone entirely. I chose this paste from the materials used and it's high reviews when I bought the DA8s. Apparently the HY 883 nano-particulate structure, micronized aluminum and zinc oxide, it's non-conductive also. It cures "hard" but can be removed. When I removed the bottom of the DA-9 I was shocked at how the two power chips didn't have an even coat, or even full coverage of the amplifier chipsets. Very haphazardly sorted squirted on, and what looked like a finger to slightly even it out.
In conclusion, upgrading the paste removed all the noise that was induced by turning on my tube amplifier that was connected via RCA from the RME DAC. The original thermal paste is not put on cleanly, or even spread uniformly between the two chips. Replacing the thermal paste eliminated the white noise that the tube amplifier was picking up, and or putting out. The performance/sound of the DA-9 remains unchanged I expect it'll run cooler once the paste sets and hardens.
If you are so inclined to replace and remove the original paste, you can use rubbing alcohol, which I don't recommend. I used spray type flux remover on lint free shop towels. It takes off the original paste without leaving any trace that you were ever in there except for the silver coloured paste and not the white cheap thermal grease. And grease is really what it is. It wasn't intended for ultimate performance of cooling or for better thermal conductivity. Especially how the factory had it squirted on. At least 60% of the two chips had zero paste on them.
This paste has an inadvertent benefit of helping reduce EMI/RFI. It's available in various sized tubes, comes with a finger glove, a plastic spreader. Easily found on Amazon. I bought the 2mg tube.
I will let you guys know if my amp suffers any ill effects. I highly doubt it since I had zero issues with the same paste on the DA8s.
Happy listening folks!
PS, use precision 2mm wrenches/hex screwdrivers, the screws are really cheap material, you want to make sure that the hex screwdriver or whatever tool you use goes all the way in. The screws are extremely soft.
