Since this is a discussion on the SMSL DA-9 and some users have noticed noise issues, I'm posting this product that aides in combating EMI.
Oyaide Electric MWA-010T
Electromagnetic wave control material tape, 10mm width. Or in proper English, it's a 0.1mm thin tape that is 20mm in width. It's a sticker, so you can wrap wires, you can stick in on any surface *take care of electrical contacts as it will conduct electricity*, I've used the 0.3mm material on my tube amplifiers output transformers, the majority of the metal chassis, and it doesn't raise the temperature measured with a temp-gun when applied. It also eliminated microphonics in it's entirety. It's about $40 per roll, about 5metres. It has a noticeable effect when applied around or behind speaker binding posts improving clarity. And that's not some marketing gimmick, it is an audible one. If you wrap film capacitors with them, the negative effects of inductors in a passive crossover becomes clear, somehow this material improves clarity. If you know the term Otaku, which means literally ultra geek, then this is the type of stuff that Japanese audiophiles purchase simply because it does work. It's better than a faraday cage in how it works. People over here apply a larger sheet A4 paper sized, slightly smaller than US legal letter sized 0.3mm thick sheets on the back of their fuse panels. Japanese apartment complexes often times don't have a third post or earth. Up until very recently, they had the same width posts for the plugs. Polarity wasn't a concern, though professional electricians would always confirm the polarity. The only issue being that you might plug your device in the opposite way. On any digital device such as a CD player you would hear a difference. I purchased a non-conductive tester so I can check the polarity of every socket in my apartment to be sure that they have it right. Just for kicks, I turned the plug around on my cd player, a Rotel which has a traditional plug, but is missing the third middle post or earth, though subtle the sound was indeed different. We do live in a soup of invisible electrical waves all around us. So it makes perfect sense that we are picking up noise more and more. There are ways to combat this issue as I have posted in previous posts.
I would probably apply the tape where the yellow material or tape is on the switching psu.
Mainly I want people to know how well this little amplifier plays music, and does justice to music. We can look at the specs and be in awe, but the way it sounds is truly something that is special regardless of price. If the amplifier was in a larger more substantial case, had a major brand name on it, you would pay a significantly larger sum for it without hesitation. The only reason why people are hesitant is because SMSL is known as "budget". There is nothing budget about the sound this amplifier is capable of.
The specs that mx2 posted, and simplified:
LOF350-20B24 Air cooling Output power 199.9w 24V/8.33A 22.8-25.2 *measured at 230VAC 93% efficiency/ 3200uf 105℃ /20.5CFM 350.4 24V/14.6A
