So you guys don't think the conductance and quality of the materials will make cables sound different? Any concrete proof that cables with different materials conduct signals the same way?
Different metals don't conduct electricity in the same way.
Conductance does matter when low load
impedances are in play.
Impedances have different resistance and phase characteristics for different frequencies.
Cables can have very different resistances and capacitances and somewhat differing inductances.
Some cables can easily pick up HF or audio frequency electric and magnetic fields and radiate them as well.
These differences exist due to geometry and used materials.
Cables do conduct signals differently with a 100% measurable certainty.
Science depends on this, even audio science depends on this.
One would have to ask the following questions.
When you say... cables sound different are you talking about
A: cables loading electro-mechanical sensors like microphones (of all kinds), MM or MC cartridge, Ceramic cartridge, magnetic pickups.
What is the source impedance of those 'sensors'... what is the frequency range they encompass ... what load impedance/resistance do they require to stay within specifications.
There are loads of different types of cables for those type of sensors.
B: Interlinks that conduct line-level signals.
What is the source resistance/impedance, in what type of environment are they used (heavy electro/magnetic screening required or not).
What is the length of the cable.
What is the load at the end of the cable (pure resistive.. with a capacitance or input transformer).
What type of connection is used (2 or 3 wire)
Is the ground connected
What screening is used
How high is the capacitance.
What is the desired upper frequency range (and specify how many attenuation at that frequency)
C: Digital cables
What type of connection is used. (SPDIF is not the same as the various USB options)
Which frequency range should it have to avoid to severe timing errors due to HF roll-off
What is the source and load impedance as well as that of the cable.
D: Power cables
What current can they handle.
Are they used on a device that emits high levels of HF signals (due to poorly filtered SMPS for instance)
Are there decent fitting connectors on it.
Are they fuse protected or not.
What currents actually pass through the cable
E: Speaker cables.
What is its length of the cable.
What is its resistance (round trip so 2 connectors added)
What is the load resistance
What is the power level that has to pass through the cable
What is the maximum frequency range you require
What is its capacitance
F: headphone cables.
What is the load impedance
Is the cable a 3 or 4 wire connection.
Is the signal balanced or single ended and in case of the latter is the common resistance low
What is the length
Those are the aspects that matter (probably not all aspects are written down).
This means some cable are better suited for specific tasks than others and one cannot use the same cables for all circumstances.
What specific cables and sound qualitiy changes/properties are you talking about ?
