Hello,
I have the Skoll, and I sent my original back for replacement as the left channel had a "buzzing" type noise that was clearly audible when you put your ear up to the midrange and tweeter. This did not present itself on the right channel. The replacment Schiit sent was better, but the same problem. I have 2 other phono stages on hand, a MoFI Studio and a Rega Fono, neither of these have the noise in the same system, using the same equipment.
I've also swapped cables, check the same RCA inputs using other gear, tried plugging in to different outlets etc.... When I swap the L and R RCA's coming out of the Skoll into my preamp (Schiit Kara) the noise switches sides. Again, this is only with my ear up by the speaker, less than a foot.
I guess my question is, did you hear anything like this when you tested? I'm baffled, and I seem to have isolated this to the Skoll, both units I've had.
Any input welcomed!
Thanks,
Chris Rud
