i believe the smsl vmv a2 does this as well
there is no dac...
the s/pdif gets converted to pwm so pcm is 'bypassed'
as people have said, this can lead to higher quality simply because an unnecessary step is eliminated
I was surprised that the A30 was suddenly released.
From the contents of the product, it is the Sabaj version of SMSL A2. I don't think the chip configuration has changed either.
PCM1804 (ADC) + XU208 (USB) + AXIGN AX5689 + STA516 * 2
Composition. Looking at the photo, the layout of the board around the amplifier is the same.
Only Pi Zero 2W has this problem. I think it is something related with the microUSB of the Pi Zero 2W. I used later the same microSD (picoreplayer) card in a Pi 4 with no problems. I will check again with a powered USB hub for the Pi Zero 2W and come back here with the result.Toku in the first page of the thread explains this.
Today I plugged in and tested a 3rd OS for the Raspberry PI 4 with Volumio 2022, and still no problem with the Xmos.
I apologize, I’m new and a complete novice…. What is the point of this amp with a THD of 10% at rated power output,
Welcome, the short answer is that the industry will often specify watt at 1% or 10% typically at 4 ohm. It can be plotted on a graph like below link. Obviously we are more interested in the good performance of an amp. Usually there is a sweet spot.
Understanding THD+N Charts
Hi all, trying to understand thd+n charts. Pl. take a look at following. (Charts are from audio poland website of Denon and Emotiva amplifiers) Am curious why some charts starts (0 or 0.1 Pout) higher and some lower. Is it because of Noise measurements are combined with THD measuremens ? what...www.audiosciencereview.com
Also, remember that the effect you get from an amp highly depends on the impedance profile (another graph) of your speaker and the sensitivity of your speakers.
Where did you get that?View attachment 253922
Important amp upgrade complete.
From Amazon it's the "mxuteuk" knob comes in a few colors. Since it has a set screw it fits a little nicer than stock and imo makes the flashy gold plate less out of placeWhere did you get that?
It's weird this day and age that any amplike this doesn't have an independent crossover with fully variable slope for each channel and 5-10 peq bands - I mean, car audio stuff had that in their cheap head units 20 years ago.@peterwen
As a recent owner of this neat little amp, there are a couple of items that I'd like to suggest for consideration in a future firmware update:
1) Speaker left / right balance adjustment
2) Addional subwoofer LFE Cross over frequency selections (e.g 50 & 60Hz). The current 70Hz minimum selection is a little high.
I,m currently enjoying re discovering my music collection through this amp
Car audio is ahead of home audio in some ways. Class D, active EQ, 2 Ohms drive etc.It's weird this day and age that any amplike this doesn't have an independent crossover with fully variable slope for each channel and 5-10 peq bands - I mean, car audio stuff had that in their cheap head units 20 years ago.
Hi. Is this knob metal or coated plastic? ThanksFrom Amazon it's the "mxuteuk" knob comes in a few colors. Since it has a set screw it fits a little nicer than stock and imo makes the flashy gold plate less out of place
Now if only we could swap that logo with a vu meter...
AluminumHi. Is this knob metal or coated plastic? Thanks
Is it possible to drive a passive Subwoofer with the sabaj a30a? Amp -> Passive SW -> Speakers ? Thanks
