OTOH, full-range mains count as 2 more bass sources. If the goal is to produce bass in multiple locations, why cut bass from speakers that can handle it? Not saying they won't need EQ down there, just that octaves of reduction seems backward.
That's my feeling too, especially since like Don I use Salon2s, which have a rather peculiar architecture including a 150Hz LR4 crossover for the woofer section. Of course, I'm only using one pair of Salon2s, not six of them like Don.
My room, set-up, and mains placement looks nothing like Don's, and it also looks nothing like Toole's either. This is Toole's room that Don was referring to:
https://www.thescreeningroomav.com/...te-Real-World-Home-Theater-and-Listening-Room
Interesting how Floyd uses four subs in his room, but in the article never describes them by name or model. Perhaps only Harman equipment is mentioned (unless I missed something), so perhaps they're not Harman subs. Given the rather, ahem, unusual placement of the Salon2s, I would guess that the resulting bass response from such near-wall placement might be one reason why Floyd chose an 80Hz crossover for smoothness, but I'm just guessing.
I've had my Salon2s in two rooms now in two houses and I don't mind saying that from a bass smoothness perspective they are a PITA for placement. They weren't that way in the dealer's room I auditioned them in, but they have been in my two homes. Other speakers have not been so annoying. Go figure. So I've always placed the Salon2s for best imaging and mid-high smoothness and fixed the bass octaves with subs and manually defined and set multi-band parametric EQ for the sub(s). You need a measuring tool like REW, OmniMic, or XTZ to tell you what's going on. The sub(s) are placed for best bass response in the octaves that the mains alone need correction. Then you use the parametric EQ bands in the sub or with a DSP to shape the sub(s) response. I use the so-called Harman Target Curve as an objective, which means a rising bass response and a falling HF response:
There are three big challenges with this strategy. First, IMO you need truly full-range mains to really function as two additional bass sources. That means real 20Hz bass response. Most aren't. None of this flat to 20Hz at 75db stuff either. If your mains can't do 90db at 20Hz at one meter, I'd just use an 80Hz high-pass filter and call it a day. Second challenge, if you're using one or two actual subs you need to have the flexibility to experiment with sub placement. If you can't, and the subs have to be in specific locations, you might as well just go with three or four small subs like Don and Floyd use. Third, you need a pretty big room with a high ceiling to make this work right, so that you don't have really ugly modes and nulls to deal with. Most people really don't have the room or the equipment to answer all three challenges in my experience. And even if you do you're looking at hours of experimentation and tuning, and that's just for stereo mains and one sub.
One other observation about Salon2s, well more about the other owners. I've only met two in person. Both had their Salon2s selected and installed as part of HT systems done by HT contractors, like Amir's company. Both systems had multiple subs. Neither one of the owners could tell me if their system used a high-pass filter for the Salon2s or not. All they cared about was the end result, not the details. Sometimes I wish I could be more like that.
