Rookie: Measuring amp setup
BeeKay
Germany, Europe, planet Earth
I would like to measure my elderly AB amp (cannot find any tests online) and looking for some advice on cost optimal, used gear plus software (MacOS or Windows) needed. Not an EE but I use to get tinkering done. Is there anything that could be recommended well away from an AP or similar top notch stuff?
E1DA Cosmos ADC with the 43V input and some non inductive resistors. Multitone tool.
Take a look at my 3 generations of Marantz integrated post which is when I tried measuring amplifiers for the very first time :)
If you want something out of the box that will just work, the QuantAsylum gear is good value for money.
By the way, you will need dummy loads to measure a power amplifier.
