- Joined
- Jun 5, 2020
- Messages
- 5,091
- Likes
- 4,019
I'm having a bad time getting the Apple adapter to work with Wavelet. I might just have to keep my Pixel 4a for headphone duty.
Are you set on the form factor?What would be the number 2 pick after the Apple dongle? Thinking about returning it and trying something else.
I would say not really. The best is something with a hard body that fixes in place. I tried one from Amazon but it had audible noise. There is not a lot of options like that, so I'm not against using whatever works best.Are you set on the form factor?
Have a look at the tanchjim space lite (not the regular space reviewed on here). Good price, decent build, sounds fine to me.I would say not really. The best is something with a hard body that fixes in place. I tried one from Amazon but it had audible noise. There is not a lot of options like that, so I'm not against using whatever works best.
Is there a comparison with the Dell equivalent, 3GVVD? Or perhaps some information about which, of those tested, it is similar to? It comes free with an XPS laptop and I am using it, through an ICY BOX powered USB hub with Sennheiser HD-650. It has enough power on its own but I wonder it a dedicated DAC would be be better. Thanks for any comments or hard information.This is a review, detailed measurements and comparison of Apple's USB-C adapter to the current and last version of Google Pixel headphone adapters. The Apple adapter costs just $9 including one day shipping for free. The Google dongle costs $12.
Not that any of these are large by any stretch but Apple's is also the smallest of the three:
Oddly there is no apple logo or markings on the device. The others don't have it either but I thought Apple would insist on that.
All three adapters work in Windows with the appropriate adapter and that is how I tested them, allowing my analyzer to fully control and quantify their performance.
Format wise, Apple's supports the key ones:
So very similar to Google Pixel V2 and better than V1 which only supported 48 kHz.
Note that volume control in Windows is active at all times even if you use WASAPI exclusive mode!
Not much else to talk about than getting into measurements.
Measurements
As always, let's start with our dashboard view at maximum volume:
Oh wow! That is good. Very good for a dongle. Here is how the SINAD compares:
As you see, it leaves both Google dongles in the dust. Mind you, built-in DAC in LG G7 ThinQ is much better still so Android fans don't need to kill themselves.Clearly someone cared about audio performance here in design of Apple dongle.
Let's look at jitter:
That's massively lower noise floor and distortion spikes than the Google pixel V2.
Seeing how this is a semi-serious DAC performance, I thought I run some adult tests on it like Linearity:
Most excellent again for something that is tinier than your fingernails!
Here is Dynamic Range:
The most important metric for these is how much power they have. There was some criticism of my Google Pixel measurements so I decided to remeasure them and refine the graphs and setting. While Google Pixel V2 repeated its past performance, the V1 produced less power. I don't know what is up with that. But here is the data anyway:
The Apple USB-C headphone dongle betters both in noise. It then proceeds to produce much more power than Google Pixel V2 and a bit more than V1.
Here are the results for much more stressful 33 ohm load:
Here the noise performance is similar but the Apple Dongle has a commanding lead over both Google dongles with respect to power.
Putting these in a graph we get this (sorted by 300 ohm power):
As we see, the Apple USB-C adapter even beats the small thumb drive sized Audirect Beam!
Story doesn't end here. Let's look at the output impedance:
At 0.9 ohm, the Apple USB-C dongle has near ideal output impedance whereas Google V2 is far higher at 7.6 ohm.
Listening Tests
I started my listening tests with my AKG K92 headphones. Here, there was ample power with excellent fidelity when using the Apple headphone adapter. Hard to imagine this much oomph coming out of such a tiny thing. The extra power was very audible as compared to Google V1 and V2. I am listening to the Apple dongle as I am typing this, having to keep the Windows volume control at just 18 out of 100 on my headphone electronic music.
Switching to high-impedance 300 ohm Sennheiser HD-650 nearly killed performance. The sound was OK but bass is week and dynamic range just not there. Here my reference is more powerful desktop and battery operated portables.
Finally I tested the Hifiman HE-400i. This wasn't nearly as loud and dynamic as AKG K92 but still quite good!
Bottom line: if you have a lower impedance headphone or an efficient one, there is no reason to apologize for using the Apple headphone adapter.
It is time for us Android users to crawl under a rock.Apple showed us that a bit more thought and engineering put in a dirt cheap and small audio product can produce respectable performance. The objective performance gap with Google dongles especially with their regression to version 2 is vast. This is both on objective front and subjective listening tests.
Note that my testing is all on Windows. I attempted to test on my Samsung S8+ and got odd results. Using both Google dongles, all they did was route the not so good sound of the internal DAC through the dongle (???). With Apple dongle I got music but level was very low. So if you plan to use the Apple dongle on an Android phone, you should do some compatibility testing.
FYI I have two other dongles to test in the future. For now, I can recommend the Apple USB-C headphone adapter. For many people it may replace the portable thumb drive dac+amps.
Now please forgive me as I go drown out my sorrows as an ex-Microsoft guy having to recommend an Apple product....
If you like this review, please consider donating funds to support these reviews using either:
Patreon (https://www.patreon.com/audiosciencereview), or,
upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
Where do you see that?Which pics can I read the color/frequency response of the Apple type C dac dongle itself? Because I see that the dac is boosted in the treble region.
No, I'm asking for bro haha. Where could I see?Where do you see that?
Per your post :No, I'm asking for bro haha. Where could I see?)
P/s: Ah I mean my ear hearing.!
Amir didn't test frequency response, because 99.5% of modern DACs are ruler flat. They don't have a sound signature.Which pics can I read the color/frequency response of the Apple type C dac dongle itself? Because I see that the dac is boosted in the treble region.
Thought that's what you probably meant. How do you know the treble is elevated? If compared to other dacs, which and how did you compare? And with what speakers /headphones?No, I'm asking for bro haha. Where could I see?)
Ah, it is interesting information!Amir didn't test frequency response, because 99.5% of modern DACs are ruler flat. They don't have a sound signature.
The Apple dongle is no exception:
Thanks! I hear the difference between My dell laptop 3.5mm and My dell laptop usb -> Apple dongle 3.5mm with some IEM like audiotechnica ath im50, qkz hbb. It seems that Apple has boost at 12 13khz and a dip at 6-8khz make the sound and musicality lacked than my laptop. Hehe.Thought that's what you probably meant. How do you know the treble is elevated? If compared to other dacs, which and how did you compare? And with what speakers /headphones?
I'd have a dig around this site a little more and have a look at threads focusing on doing meaningful comparisons between electronics in the sound reproduction chain.Thanks! I hear the difference between My dell laptop 3.5mm and My dell laptop usb -> Apple dongle 3.5mm. It seems that Apple has boost at 12 13khz and a dip at 6-8khz make the sound and musicality lacked than my laptop. Hehe.
How do you know it's not the laptop sounding poor by comparison because it has the inverse of the colouration you've projected onto the Apple dongle?Thanks! I hear the difference between My dell laptop 3.5mm and My dell laptop usb -> Apple dongle 3.5mm. It seems that Apple has boost at 12 13khz and a dip at 6-8khz make the sound and musicality lacked than my laptop. Hehe.
IEM ath im50 and QKZ HBB. Oh I will check default smart audio processing DSP soft of my laptop tomorrow, it still boost the sound as well. Thanks! Anyway it is interesting information! To checkI'd have a dig around this site a little more and have a look at threads focusing on doing meaningful comparisons between electronics in the sound reproduction chain.
But let's assume for a minute your comparison was valid. How do you know the Dell was flat and the apple has peaks and dips and not the other way round?
It's highly unlikely either do by the way. But again, what were you listening to them on. I'm assuming headphones but which?
Haha, very possibilityHow do you know it's not the laptop sounding poor by comparison because it has the inverse of the colouration you've projected onto the Apple dongle?
This is the Lightning version but I'd expect it to be the same as the USB-C one <https://www.kenrockwell.com/apple/lightning-adapter-audio-quality.htm>Which pics can I read the color/frequency response of the Apple type C dac dongle itself? Because I see that the dac is boosted in the treble region.
