Review and Measurements of SMSL SP200 THX HP Amp
maxxevv
Alrighty. Edited.
BTW, I did some reading one or two years ago on those designs. It's just the extremely low impedance and high current draw it needs. There were a few similar products back then. The conversion box he used is just designed for power amplifiers, which is deliberately lowering the sensitivity. The other companies who make these have converters suitable for headphone amps.
There aren't many ribbon driver headphones on the market at all. I know the Raal's sound pretty good to my ears, no idea how the others sound outside of their interweb sharing / reviews.
Outside of test prototypes / proof of concept presentations, I only know of 2 (manufacturers) who have made their products available on a consumer basis. One being Raal and the other being located in China and offers 2 models. I am tempted to try those out. Shall see if there are any good offers for them come 11.11 sale.
SMSL_Liu
It is a very different output level. And as noted, we don't know what filtering was used (that would be to the left of the screenshot shown).
Dear Amir, finally I got time to review this post, very much appreciated your work, maybe I can provide you with some of our information. The sp200's amplifier section has only 2 channels, but it is designed in a "balanced" way. According to the THX guidelines, all XLR socket traces are returned to the amplifier. And because it is an unbalanced amplifying part, the RCA does not need to pass an XLR->RCA amplifier like the XLR input. Therefore, the performance of the RCA input is the best. We test the input using 5Vrms (because this is the best point of our ap's signal generator), the A-WTD is not used, the attachment is the result of the RCA and XLR inputs we tested, all with a 33OHM load, where the XLR input is 0.00009%, because this is the result of the 1st prototype test. For 2nd generation prototype, we modified the resistance of XLR-> RCA, THD+N down to 0.000085%, and the results of the five prototypes were consistent. BTW, we are using APX555B, I also attached THD+N of the APX555B 5Vrms.
maxxevv
@amirm mentioned:
"As a side note, when I designed this test, I did not think to turn on the low-distortion mode of my audio analyzer thinking it was not needed. It actually is here! When I turned that on (not shown) distortion at the bottom right was even lower. For consistency, I am leaving it the same but you should note that with this setting, the distortion of my analyzer is the limit, not these headphone amplifiers! "
Would be interesting to show the results of the mode turned on. ASR is in the business of showing what SOTA is capable of, so I guess it would be insightful/useful to show that separately too ?
MediumRare
Chicago
So we are spoiled for choice, for sure. apos.com said the SP200 will be available soon. Any suggestions how to choose between it and the Monolith THX887?
I have cans with about 50 ohms impedance and can use the balanced output, so I am leaning toward the Monolith due to the extra power. But maybe that's academic if I'll never go about 1 watt.
My DAC will be the D50s, so RCA output only, no need for balanced interconnect.
The other factor I'm considering is the rear-panel pass-through available on the Monolith, so I can leave it connected in series between my DAC and main amp.
What do you experts say?
Veri
If you want the pass-through and balanced the monolith seems the way to go. The extended warranty is also nice.
On the other hand the D50s is a great match with the single-ended SP200 and is cheaper.
Up to you :D
olinko
First post! I'm hoping to buy the SP200 and the SU-8 combo on 11/11 but I'm annoyed that the SU-8 is gone from the official SMSL store on AliExpress.
I'll take the SP200 over the Monolith just so I don't have to import stuff from the US into the EU, I've had nothing but horrible experiences.
Plus, if you're getting an SMSL DAC, might as well pair it :)
MediumRare
Chicago
Veri
or965
@SMSL_Liu Is the amp will work with low impedance balanced driver earphones, like for example a earphones with a impedance that vary with a minimum of 8 ohms ? I ask it as the DROP THX 789 product manual warn to use with low impedance earphones .
