JustIntonation
- Joined
- Jun 20, 2018
- Messages
- 480
- Likes
- 293
Uhh the label states the bottom blue-green one is SU1 + Holo Spring DSD?I did come across this measurement on computeraudiophile from a holo spring, plain USB vs external I²S from a singxer SU-1
lower traces are using Spring USB input, upper using SU-1
You can see here the spring does dramatically better on jitter than the SU-1. I wasn't sure whether this meant the SU-1 wasn't very good, I²S is a bad interface or the spring USB is just that good...
Also what kind of measurement is that? It claims to be a DAC measurement but a DAC measurement that has a noisefloor of less than -162.1dB? No way.
