Oh, I misspoke. The owner had given me these iFi AC iPurifier devices to test. I had thought there were series devices, i.e. you plug something into them. But no, they are parallel noise filters. So I could add them to the power strip which fuels both the Audio Precision analyzer and Schiit Yggdrasil. I will do a much more extensive review of them later but for now, this is what is claimed:
https://ifi-audio.com/portfolio-view/accessory-ac-ipurifier/
Even though it doesn't have *any* attenuation at 10 kHz (start of the graph), it is supposed to make my audio sound better? I don't think so. But let's measure the Schiit Yggy with it and see how it does.
This is a high-resolution (256k point) averaged (4 times) FFT:
Definitely no reduction. Indeed if you squint there was more noise (in red) prior to plugging it in but that is probably run to run variation.
I performed another test which was to have a running chart showing THD+N distortion at very high magnification (vertical scale) and plugged in the AC iPurifier half-way in the middle and then let it stay there until the end:
Not a thing happened. Those tiny up and downs are natural variations from the device/measurement.
As it should be. No device this tiny can have a prayer of filtering audio band frequencies. And even if it did, it would have to then reduce the noise internal in the unit by significant amount which again, it has no prayer of doing so.
Owner was kind enough to give me three so I will test them together and see what happens.
For now, this is a "plus" for Schiit Yggdrasil that it is of no need of AC tweaks. It does what it does without such.
