I've designed a headphone amplifier using OPA1612 as a gain stage and using OPA1622 as output buffers. Each channel has 4 outputs summoned, thus lowering the already really low noise by around -6 dB. I use TPS7A4700 and TPS7A33 low noise DC to DC converters with 4 µV/16 µV noise. Only thin film 0.1% 10 PPM resistors in the audio path. I'm currently working on my last revision with further improvements in the power supply.
Can you please find a scope to measure this beautiful headamp with sine & square waves at 20Hz, 1KHz, 10KHz, 15KHz and 20KHz? You could you the built-in signal generator from the scope, if available or you could use a very good DAC and audiocheck.net or similar website to generate the correct sines and squares.
It's very important to see when the output buffer starts to distort (to bend the sines or to flatten the output signal) and if they get overheated.
Also, Q401 is one of the best devices to test this headamp, right?
