- Thread Starter
- #21
Here is the dynamic range:
They got much worse distortion figures, wonder what bandwidth they are using:
This is a review and detailed measurements of the NAD 7050 integrated DAC, amplifier and streaming playback. It is on kind loan from a member. It appears the product was announced in 2014 and since discontinued as I can't find it on sale anywhere. The cost was USD $999 from what I can gather.
The unit can be used both horizontally and vertically. A rotational sensor changes the display orientation conveniently. Here is its upright position which I consider better for sound since the electrons can naturally free fall into the speaker terminals:
The outside has what appears to be some sort of rubber glued to it. It is soft to touch but picks up dirt very easily and is impossible to clean due to sticky nature of it.
The large knobs imply great feel which they don't have. They wobble as you rotate them. The larger knob is the volume control which had an odd delay in updating the display as you rotated it. Overall, a good effort has been made to create an unusual design but didn't quite get there in feel and functionality.
The back panel shows off the inputs and speaker output:
For my testing, I focused on USB input as I suspect that is the most common interface for consumers. Alas, the USB interface is class one so only goes up to 96 kHz. To get the advertised 192 kHz you need to use the other inputs. I downloaded the NAD drivers which nicely gave me ASIO interface for testing.
There is an app to control it and I downloaded it from Android play store. It is a simple remote control but allowed me to change the audio-out to be full range so I could use it for DAC testing. Otherwise it is filtered for subwoofer out. Despite its simplicity the app crashed on me once.
There is no analog input so I had do all of my testing with USB digital interface.
As expected from a brand name company, the NAD 7050 comes with full set of safety and emissions regulatory certifications.
The amplification in NAD 7050 apparently is a scaled down version of what is in NAD M2. Here is what NAD says about it:
My read is that it is a power DAC similar to Lyngdorf TDAI-3400 I reviewed recently. Measurements will confirm if so.
DAC Measurements
As usual, where possible I try to isolate the performance of the subsystems, in this case the DAC. Here is our dashboard view using USB input/Line Out. I hope you are sitting down if you owan the 7050 and use it as a DAC:
What the heck is going on here? Even at 0 dB the unit doesn't get to 2 volts yet it severely clips resulting all of those harmonic distortions. Dialing down to -2 dBFS improved performance but just to 83 dB. By then the output voltage was even lower, making it not so useful as a DAC anyway. My thinking is that this is a split off output from the power amplifier as opposed to a traditional DAC output. I guess for the assumed subwoofer duty it may be OK.
Naturally, with the SINAD as measured falls at the bottom of the graph of DACs tested:
After the first bad impression, the 7050 almost nails the rest of the measurements such as linearity:
And jitter:
Since USB doesn't support 192 kHz, I had to run a different multi-tone test at 44.1 kHz:
Amplifier Measurements
As usual, the dashboard view is at 5 watts of power into 4 ohm:
As power amplifier measurements go, this is not too bad actually and almost matches the vaguely stated 90 dB spec by NAD.
Power versus distortion+noise is also pretty decent:
The downward part of the curve is always dominate by noise as the output level is low. Here, that part of the curve is flatter than I am used to seeing which is good as far as level of noise. Likewise, distortion is kept under complete control until onset of sudden and massive clipping at 54 watts. This too is good (sans the clipping). Stated rating is 50 watts at 4 ohm and we beating that a bit which is nice. Then again, 50 watts is not that much power in grand scheme of things.
THD+N versus frequency using my default 45 kHz bandwidth shows pretty awful results (in red):
Suspecting ultrasonic noise at play, I re-ran the test with 22.4 kHz (as with the dashboard) in blue which shows that effect quite conclusively. One channel is worse than the other though which is strange. Note that the drop above a few Khz is due to bandwidth of the test being too low to capture all the harmonics (and hence the reason I like to use 45 kHz bandwidth normally).
Broadband FFT shows of 1 kHz tone shows us what is going on:
This is without my Audio Precision high-frequency filter (AUX-0040). All the other tests used that filter.
On the extreme left we see our 1 kHz tone as a spike rising to 0 dB or so. We have a single and large spike at 850 kHz. That seems to indicate to me that 850 kHz may be the switching frequency. Given its high frequency, the power DAC is running likely with as a single bit converter which would create a lot of quantization noise. Noise shaping is used to push that above 30 kHz or so with the peak at about 80 kHz. This is the drawback of power DACs as we have seen in the Lyngdorf and SONOS Amp versus class D amplification which doesn't need noise shaping. You can see the effect of high frequency noise in the thickened sine wave of the same signal in the inset.
Usually, by the time I get to the end of testing, I have a good idea of if I like or don't like a device. Here, I am not quite sure. Let's agree that no one should be using the NAD 7050 as a DAC with external amplification as NAD suggests in the manual. You will be listening to a heap of distortion products with anemic output to boot.
The amplifier seems to have some good tricks under its sleeves with lower than normal noise and very controlled distortion until a very hard limit. My issue there is the 50 watt rating for a $1000 device. That is just not enough power for a product in this category.
Seeing how the NAD 7050 is discontinued, maybe it doesn't need my recommendation or lack thereof anyway. So I will leave it at that.
Money was donated for gas to go and get some good fish chips in town. Need a few more coins to pay for the meal itself though. Please consider donating funds using:
Patreon: https://www.patreon.com/audiosciencereview), or
upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
I have been using one of these D3020s in my study system for a few years connected by USB to my work computer and to old Proac EBS speakers. The room is 12’ x 15’ and the display shows around -15dB to -20dB fwiw.OK, no problem. Do you have another NAD product in the queue? D3020 would be a nice cheaper alternative, but it was already measured by Stereophile -- https://www.stereophile.com/content/nad-d-3020-integrated-amplifier-measurements
I think you should remeasure this device in a horizontal position as free fall of the electrons must have caused such poor SINAD figure due to their collision with terminals.![]()
Your joke is actually the kind of nonsense one is likely to encounter at a "high end" store. Years ago (true story) my dealer sold me an Acoustat system (if anyone remembers them). MOSFET amp and preamp, plus tall electrostatic speakers. It was pretty good value, in the scheme of things. The idea was that FETs were supposed to sound 'tubelike,' and tubes were authentic 'high end'. The store also sold a line of tube gear; I think it was Conrad Johnson. Anyhow, the salesman-owner told me how he was told by the tube brand's rep that a competing design (Counterpoint, another tube brand sold back in the day), using horizontal tube sockets (in order to sort of mimic the Mark Levinson preamp look), might not be as good as vertical tube sockets, since the tube filaments could sag the wrong way, causing electrons to introduce time smear. I swear the guy was serious. In the early days of 'high end' we were all mostly idiots and fools. Some still drink the kool aid.
why? if it clips the same way, that should be easy enough to avoid.I'm currently writing another post on my quest for a new DAC/AMP, and this review adds to my prejudice against the new NAD 3045, which seems to be more of a replacement for the D7050 rather than addition to their DAC/AMP product line.
...In the early days of 'high end' we were all mostly idiots and fools. Some still drink the kool aid.
How do products with faults like this get released???
Because people don't know any better; when it comes to audio the only way to know that there are higher quality choices is to hear better examples.
If the reviewer likes it, for whatever reason, he just keeps it, or maybe even 'buys' it for a huge discount.
I don't know, but my guess is that a company like NAD relies on marketers to tell them what they can likely sell, and at what price point. Then in-house or contract designers are given a parts bin to work with, and told to come up with something.
The unsuspecting consumer has nothing else to go by, other than perhaps what a brick and mortar commissioned salesman might tell him. Or, if he doesn't have audio salon dollars to spend, he goes on the Crutchfield site, calls up an 'advisor' and makes his order based on price. And that is that.
Back in the 'stereo' day you had at least 3 mainstream magazines that routinely did (at least) cursory measurements that could be used to validate published specs ...
