Thank you for your feedback! I will clarify it and then report it. do you know why my wiring could be a problem? is it due to the unbalanced source?
No, nAMPON enables the amplifier by being grounded...
If you have a basic volt meter then you can do a quick check to make sure the binding posts aren't inadvertently shorting to ground. Same for making sure the pins on the XLR connectors are correct. When I built my NC400 monoblocks I recall that everything plugged together so the chances of having something reversed was really small. Also wondering if the red leds are all lighting up as they should.Yes i think so too.
Thanks for the qick answers!
If you live in a country with mains @ 220 V, take a multimeter and check all supply rails referenced to chassis (carefully).hi guys,
sorry for my beginner questions, but I can't get on without you.
i have now soldered both nampon cables through the metal eyelet on pin1 of the xlr connector - still have the same problem.
here are the actual pictures.
What did i do wrong?
Hello,As a general question relevant for all amplifiers, what is your view on the validity of thd + noise going up to 90 kHz when beyond 20 kHz its is not audible and very few speakers will reproduce beyond 30 kHz? It may also make comparison with data available elsewhere difficult.
My view is it isn't valid, but happy to be convinced otherwise.
Ultrasonic garbage can be viewed with an fft which is more informative. As a second question on that point, ultrasonic garbage output from a dac can be of issue for a subsequent Amplifier. Is USG an issue for a speaker which has no response to it? Think of how class D works.
Hi guys
I have found my mistake. I forgot to set J6 and J7 to unregulated vaux on smps1200.
Now I am in the game.
Wow!!
it’s just that the n500 don’t seem to have such high rates of overheating/failure and measure much better closer to the purifi modules.
Yes my mistake.In what way does the nc500 measure better than the nc400?
but is there a problem with longevity with the nc400.
Hello All,They were introduced in 2014. If there was a longevity problem you would have found out by googling.
I suppose you are addressing longevity doubts regarding the SMPS and not the NC400 amp module itself btw.
Nobody would suggest using an underrated linear power supply for a power amp, so why they are using an underrated SMPS is a mystery to me. Seems to work fairly well, but then expecting premium results is nuts. IMHO.
Yes, barely. And the testing on this site shows increased distortion when driving them both of them hard which does not show up when they are driven individually. You want the best, don't use a marginal power supply.Depends on your definition of "underrated". The Hypex datasheet shows the SMPS600 is perfectly fine powering two NC400's.
Again, what is marginal? The performance would be even better with an even more powerful supply - where do you draw the line?
