Why does it matter? The dac will be the limiting factor in distortion measurements and in noise at most volume range.And that's why I want to see it! Now I want to send my dac in to be connected to this.![]()
Let's cut the bullshit first, it doesn't improve SNR. At max volume it's limited by DAC3. Once you start to attenuate using HPA4/LA4 you start to attenuate noise as well as output level. In this case it still doesn't improve SNR over DAC3 itself. It only preserves the SNR. Improved SNR is using digital attenuation as reference assuming noise doesn't get attenuation. Rough calculation indicates that only at higher than. 1.9/9.2 attenuation to before maximum will preserve the SNR of DAC3. Lower than that, HPA4/LA4 will take over the noise. This is happening because they are still active components.
More precisely, we need to take the resistance of attenuator into account. Regular attenuators have max noise at 50% position. For HPA4/LA4 is a little different, it's depending the implementation. But it will introduce some noise at some level.
This is much clearer. But this is common knowledge. It's simply the basics of analog preamp. (tho many preamps are very bad design) The previous post sounds like it's a "new" thing and none other have made it or stuff like that. That's not the case.No BS, we try to avoid stepping in that.
The HPA4/LA4 can improve the system SNR at all volume settings when added to a DAC3 to AHB2 system. Obviously it cannot improve the SNR of the DAC3 itself. It just optimizes the operating point of the D/A converter.
What I failed to point out is that the output noise of the LA4 is less than the equivalent input noise of the very quiet AHB2. The 1.9 uV output noise level of the LA4 is 134 dB lower than the 9.75 Vrms needed to reach the full output of the AHB2 amplifier. Furthermore, this noise level decreases when the LA4 volume is turned down below unity gain. This means that the LA4 will never be the limiting factor in the output noise of the system. The output noise will be determined by the noise of the amplifier, the noise of the D/A converter, or a combination of the two. System output noise is never determined by the LA4 at any volume setting below unity gain.
The stepped attenuator in the LA4 is a very low impedance design. Many of the resistors are less than 1 Ohm. This means that the attenuator must be actively buffered, but it can be shown that this provides many advantages including avoiding the usual rise in noise at mid volume.
Yeah I was paid. Like 100M per post.God, you truly are annoying. Are you paid to behave like a prick?
No it bothers me. So I replied. Has anything to do with you? Huh? Sorry. I'm not replying after this. Ignored.Glad you can realize your worth and sell-appointed mission.
One of the things that is unusual about the LA4 preamplifier is its low noise levels. As you correctly point out, "many preamps are very bad designs". Most preamplifiers will add noise if placed between a Benchmark DAC and a Benchmark AHB2. The DAC3 is one of the lowest noise D/A converters available. To the best of my knowledge, the AHB2 is the lowest noise audio power amplifier available. Most preamplifiers are too noisy to insert between these two devices. In contrast, the LA4 will actually improve the system noise. I did some system measurements to confirm the mathematical calculations.This is much clearer. But this is common knowledge. It's simply the basics of analog preamp. (tho many preamps are very bad design) The previous post sounds like it's a "new" thing and none other have made it or stuff like that. That's not the case.
I wasn't talking about in a complete system including ahb2 but a dac with preamp. I didn't mention ahb2 in my post. So that's that. I pointed out the key word was "at most volume settings". As you stated here it's consistent.
Thanks for the performance comparison. But it should be clear that it's compared to no preamp. (which is not the use case for most people) It's more realistic to compare to some other implementation or use conditions.(not saying to have to make such comparisons to demonstrate)One of the things that is unusual about the LA4 preamplifier is its low noise levels. As you correctly point out, "many preamps are very bad designs". Most preamplifiers will add noise if placed between a Benchmark DAC and a Benchmark AHB2. The DAC3 is one of the lowest noise D/A converters available. To the best of my knowledge, the AHB2 is the lowest noise audio power amplifier available. Most preamplifiers are too noisy to insert between these two devices. In contrast, the LA4 will actually improve the system noise. I did some system measurements to confirm the mathematical calculations.
Here are the results, measured on our APx555b using the SNR measurement function, unweighted, with a 20 Hz to 20 kHz measurement bandwidth:
The chart begins with a gain of -2 dB because this is sufficient to drive the AHB2 to maximum output power. At this gain setting, the LA4 improves the system noise performance by 1.1 dB. Note: The raw data shows 1.064 dB, but these numbers should be rounded to the nearest 0.1 dB or 0.05 dB. For the sake of discussion, I will round to the nearest 0.1 dB.
At a moderate -6 dB gain setting (4 dB below maximum power) the noise performance is improved by 4.2 dB when the LA4 is added.
At -12 dB gain (10 dB below maximum power) the noise performance is improved by 7.4 dB.
At -21 dB gain (-19 dB below maximum power, 1 dB above 1W when driving 8-Ohm speakers) the noise performance is improved by 9.1 dB. This gain setting will produce a typical listening level with many loudspeakers.
At all gain settings below -21 dB, the LA4 improves the system noise performance by 9 to 10 dB!
Notice that the attenuator does not get noisier at mid range. Fully passive stepped attenuators and variable resistors will exhibit a bump in the noise at mid volume settings. The actively buffered LA4 stepped attenuator does not have this common problem.
Summary:
At typical listening levels, the LA4 can reduce the system noise by 7 to 10 dB. If the speakers are efficient enough to reproduce the system noise at levels above 0 dB SPL, then the LA4 can make an audible improvement in the system noise floor. This will happen if the speakers have an efficiency greater than 100 dB at 2.828 Vrms, 1 meter. This would be a gain setting of -22 dB (which I am calculating from the nearest measured point which is -21 dB). If I run this again, I will make a measurement at 2.828 Vrms (1 W into 8 Ohms).
The differences may be more noticeable with headphones or with bridged mono installations.
First one, passive attenuator is essentially resistor divider. Mid point is where with the constant sum of the two resistors and the largest parallel resistance. And resistance = noise, hence it the noisiest.Can you elaborate on what causes this noise for passive attenuators? And is this the reason why the DAC3 attenuates its DAC output digitally instead of using its analog potentiometer?
This is astonishing. Never heard of a preamp actually improving your system. I might have to buy one of these.One of the things that is unusual about the LA4 preamplifier is its low noise levels. As you correctly point out, "many preamps are very bad designs". Most preamplifiers will add noise if placed between a Benchmark DAC and a Benchmark AHB2. The DAC3 is one of the lowest noise D/A converters available. To the best of my knowledge, the AHB2 is the lowest noise audio power amplifier available. Most preamplifiers are too noisy to insert between these two devices. In contrast, the LA4 will actually improve the system noise. I did some system measurements to confirm the mathematical calculations.
Summary:
https://audiosciencereview.com/forum/index.php?members/john_siau.2646/ open about tabThis is astonishing. Never heard of a preamp actually improving your system. I might have to buy one of these.
Wait. Do you work for Benchmark? I feel like that should be disclosed.
I wish I understood this stuff. I heard it was common knowledge that using a 'normal' preamp circuit is better then using digital control. Something about digital control decreasing resolution for every step of volume you go down, I think. But I've also heard that properly implemented, a digital volume control can be indistinguishable and sound better, and actually improve the sound.https://audiosciencereview.com/forum/index.php?members/john_siau.2646/ open about tab
btw an analog attenuator improving SNR over digital volume is very very basic of electronics. John successfully tricked another one to think this is unusual...
Yes, but it's not like John did any of the design work. He's a marketing man. Leave the praise for the engineers at Benchmark. If it wasn't for folks like John, however, Benchmark wouldn't be nearly as successful as they are now. So there's that aspect to look at it. You can look at the way John is marketing up the SNR thing with the digital pre as less of a hustle to put a different spin on an old idea, and more of a neccessary marketing strategy to survive and thrive in this modern day and age.
Are you saying Benchmark is a marketing company? That's one way to look at it.
So correct me if I'm wrong, John does work for Benchmark?
