LOL, well said John!The LA4 cannot compete with the Relentless when both systems are turned off.
Keith, Beauties in the eye and all that.It’s an abomination.
Sounds very similar to the level control arrangement of my old Emotiva DC-1 DACThe volume control for all inputs (even the DAC) was analogue! it used chip based, digitally controlled, fully balanced resistor ladder array. Four ladders to control the balanced output, which was defeatable.
I think it first came out about 12 years ago! There is a mini review here on ASR. The analogue input had a measured noise floor of less than -140dB, with minor spikes reaching -130dB.
www.audiosciencereview.com
Yes beauties, but not in this black copper scheme yuck....Keith, Beauties in the eye and all that.
As a retired machinist myself, I've stated a number of times here how much I admire the beauty of the D'Ags case work.
Some of the Pass Labs stuff comes close, but this is the Mona Lisa of Hi Fi, JMHO
If I had Elon's size of wallet, I'd probably have a room full of his components.
Even if they weren't plugged in and I was using some Benchmark gear running hidden behind. LOL
It sure costs a hell of a lot less !!!
Benchmark also has a few other competitive pieces in their lineup.
The $2950 LA4 is the pure line preamp sans the dedicated headphone amp of the $3499 HPA4
There's also a couple lower cost options of the DAC3 which can be directly connected to amps but yet include one of the best DAC's available anywhere.
Any would be awesome for a SOTA front end to a pure 2ch system.
Decisions decisions. LOL
The HPA4 would optimize the gain staging between your DAC and the internal THX 888 headphone amplifier. The SNR and THD+N of the HPA4/LA4 input stage is nearly constant over a very wide range of input gain settings. This allow the use of a 4 Vrms consumer-grade device or a +24 dBu professional-grade device while extracting the maximum performance that either device can produce.I currently have the SMSL SP400 (THX 888 headphone amp) paired with the Lynx Hilo DAC.
The Hilo's XLR output level is set to +24dBu (12.28V) and the SP400 is set on High Gain.
Eventhough the Hilo is old tech (Cirrus Logic CS4398 DACs), due to its +24dBu output, the clarity and dynamics I get in sound with this combo is simply jaw dropping.
Paired with regular 5.2V DACs from Topping, SMSL or whatever, the sound is OK, nice and detailed. But with the Hilo, it's no contest, even the SMSL D400ES with the latest ESS 9039PRO DAC sounds bland by comparison.
Trying lower voltages out of the Hilo resulted in a less dynamic sound so I will never ever buy a DAC again that doesn't have the pro +24dBu output level.
My question:
In my particular case, is there any benefit from buying the Benchmark HPA4 headphone amp?
It's the same THX 888 amp, but half the power at 32 Ohm (SP400 can dissipate 6W into 32 Ohm), and ofcourse...it's 6x the price))
SP400
Foshan ShuangMuSanLin electronics Co., LTD. founded in 2009 which located in Shenzhen, China. And our branch company VMV Technology(HK) Company Limited registered in HK in 2013. Our company is specialized in the audio DAC, stereo headphone amplifier, power amplifier, and with own R&D...www.smsl-audio.com
The headphones I use are AKG K701, Hifiman Arya Stealth and HE1000se.
Thanks!
The SP400 has "high precision low noise 256 level relay volume control" (see the link in the previous post).The HPA4 would optimize the gain staging between your DAC and the internal THX 888 headphone amplifier. The SNR and THD+N of the HPA4/LA4 input stage is nearly constant over a very wide range of input gain settings. This allow the use of a 4 Vrms consumer-grade device or a +24 dBu professional-grade device while extracting the maximum performance that either device can produce.
In contrast, the performance of a headphone amplifier with a traditional gain pot will be very sensitive the the input level of the signal. A high signal level will be required to achieve a high SNR within the headphone amplifier itself.
Sorry the HPA4 is so much more expensive than products made in China. All of those relays and precision resistors add up. We replaced a pot with 64 relays. This is not very cost-effective, but the performance is awesome. We also build our products in the USA.
Isn't this the same as yours?
I have the HPA4 and love it! There are a ton of options on setup and config. I’m not going to try to answer all your questions. You know who does have all the answers? Benchmark! I’ve pestered them with many similar questions and Dan and Rory were always patient with me and gave me excellent information. Call them in NY. They’ll give you the info you need.!!!Hello folks, I am thinking of picking up a Benchmark LA4 and am going through the pdf manual right now.
My apology for the noob questions:
1) I will be connecting "consumer grade" upstream device (dac with consumer grade xlr output) to the LA4. According to the manual, it advices to set the LA4 input BOOST to 10db on that XLR input. I am a bit confuse what it means really?
2) Do the LA4 XLR output and RCA output simultaneously so I can use the XLR output to my power amp and RCA output to my two subwoofers?
3) As per 1, 2) above, I will be connecting a "consumer grade" dac XLR output to the LA4, then XLR output to my power amp and RCA output to my two subwoofers. Does it mean I should still set the LA4 input BOOST to 10db on the XLR input?
4) I plan to use 1 RCA input at "unity gain" for connecting my Anthem MRX1120 receiver for movies and PC games AND 1 XLR input at "unity gain" for connecting my Schiit Freya +. Does it mean I just set 1 RCA input and 1 XLR input at 0db and that would mean they are now at "unity gain" = ht-bypass?
Thank you folks!!! Much appreciated
D
Received the DAC3 B two weeks ago to test with the SP400 and daaaamn...it bests even the Lynx Hilo at +24dBu. It has the same sound signature as in tonality and dynamics but it is cleaner and more transparent.I've placed an order about two weeks ago for a Benchmark DAC3 B to test with the SP400.
Can't wait to get here sooner!!!
Buy a multimeter (basic $15 model is ok).Any idea?
I don’t use the AHB2 but it should have gain settings low, medium, high.I just got my HPA4 with two AHB2.
I see that even with +10db setting the volume is not the high.
I find that I am at almost 90%.
Previously on my Denon PMA-A110 I could not go much above 40% top 50% (depends on the recording dynamic range and mstering).
My souce in from HoloAudio May DAC KTE.
All connections are XLR.
Any idea?
Where is that?-20db DIM function is engaged?
I see what you mean (the lower volume beside mute) and it's not engaged.-20db DIM function is engaged?
