GoldenOne
Not Active
- Joined
- Jun 25, 2019
- Messages
- 201
- Likes
- 1,469
I'm in EU and I got my amp from SCV Distribution, I could disable the auto-off timer. I have the running pretty much 24/7 controlled via the 12V trigger. Before that, I had it on a power/slave power socket which also worked.
When you press and hold your power button what happens? And does it explain how to turn it off in the manual that came with yours?
Hopefully @John_Siau can clarify if this is simply a manual printing difference, or an actual hardware/firmware change, but I cannot seem to disable the auto shutoff no matter what I try.
Holding down the power button on mine the mute lights come on, the left temp light flashes on and off slowly (but will immediately turn off if I let go of the power button), and then a few seconds later the unit powers off (regardless of if I am still holding down or had let go of the button).
The auto-shutoff feature remains on no matter what I do.
https://streamable.com/zmohah
