The R1s are sensational. I typed R2 above in error.Very nice gear setup! How are those TADs when the bi-amping is used and adjusted for tone control?
I’m using a Pass XVR1 as an active LPF for the two woofers, and also as an active HPF in series with the stock internal passive crossover that drives the coax. Each TAD has one AHB2 on the woofers and one AHB2 on the coax. The passive LPF inside the R1s has been bypassed. It uses iron core inductors and does not have the more exotic capacitors that are in the passive crossover that on the coax. Andrew Jones was kind enough to set up the XVR1, which has many settings. Equally important is the work Mitch Barnett did designing a convolution filter that runs on Roon.
For movies I run this as a 4.0 system, no center, no subs (my -3db with the R1s is around 17 Hz) with a Denon 4800h driving the XVR1. For music I have a Meitner MA3. A trigger operated XLR AB switch selects the Denon or the Meitner as needed.
