My Merging Hapi II does it handily.What DACs have enough voltage (9.8V) to drive AHB2 to full power at low gain?
Are we only talking about the RME and Benchmark models?
The Anthem AVM90 should be able to do it!What DACs have enough voltage (9.8V) to drive AHB2 to full power at low gain?
Could you please post pictures of your three Blades! The sound stage must be phenomenal.My Merging Hapi II does it handily.
The old Marantz AV7701 goes up to 12V rms.What DACs have enough voltage (9.8V) to drive AHB2 to full power at low gain?
This was the temporary setup until we began tearing everything down for a major renovation. The Blades (and a lot of other stuff) will go into storage for the duration.Could you please post pictures of your three Blades! The sound stage must be phenomenal.
Superb thank you for sharing! What do you use for surround sound blades as well?This was the temporary setup until we began tearing everything down for a major renovation. The Blades (and a lot of other stuff) will go into storage for the duration.
What subs are those ? JL E112s?This was the temporary setup until we began tearing everything down for a major renovation. The Blades (and a lot of other stuff) will go into storage for the duration.
I had been using Revel F206s but will be getting something else when the dust clears. In the meantime, I am looking at 3 months without a system.Superb thank you for sharing! What do you use for surround sound blades as well?
e110What subs are those ? JL E112s?
If ya want to escape the cold, come on down to the Sunshine State for a visit and surround fix.I had been using Revel F206s but will be getting something else when the dust clears. In the meantime, I am looking at 3 months without a system.![]()
Asking in the danger to derail this thread a little further, but wouldn't the design of the Blades maximize dispersion and cause more room reverb than any other speaker or am I thinking wrong? I come from a full array 4-way d'appolito which drastically eliminates vertical reverb, so it's hard to imagine for me how a speaker sounds that has basically the opposite design paradigm.I had been using Revel F206s but will be getting something else when the dust clears. In the meantime, I am looking at 3 months without a system.
e110
mytek, tooWhat DACs have enough voltage (9.8V) to drive AHB2 to full power at low gain?
The AHB2 has a 3-position input sensitivity switch. In low gain (switch down), it requires 22 dBu (9.75 Vrms) to reach full output power. In the middle position it requires 4 Vrms (14.2 dBu) to reach full output. In the top position it requires just 2 Vrms to reach full output.What DACs have enough voltage (9.8V) to drive AHB2 to full power at low gain?
any full size preamps that do ? or come close?The AHB2 has a 3-position input sensitivity switch. In low gain (switch down), it requires 22 dBu (9.75 Vrms) to reach full output power. In the middle position it requires 4 Vrms (14.2 dBu) to reach full output. In the top position it requires just 2 Vrms to reach full output.
The 22 dBu setting is intended for input from professional balanced outputs such as those found on all Benchmark products and on most high-end studio products.
The 4 Vrms setting is intended for input from most consumer balanced outputs. This setting will work for virtually all HiFi devices with balanced outputs. It should not be used with professional products that support outputs that are typically 10 dB hotter.
The 2 Vrms setting is intended for input from unbalanced RCA outputs (using Benchmark's RCA to XLR adapter cable). This setting will work with almost all RCA outputs.
The AHB2 has about the same noise performance in all settings. However, you will be hard pressed to find 4 Vrms or 2 Vrms outputs that can deliver a 132 to 135 dB SNR to match that of the AHB2.
Thank you John of your clarifying post!The AHB2 has about the same noise performance in all settings. However, you will be hard pressed to find 4 Vrms or 2 Vrms outputs that can deliver a 132 to 135 dB SNR to match that of the AHB2.
You mean drive the AHB2 on low gain? I have to ask why you want to do this.any full size preamps that do ? or come close?
No. Most hifi gear will be around the 4V mid-gain. Some would come close (as people responded above). You need something that is about +19 dBu @ 0 dBFS. RME ADI-2 DAC FS, for example, can do that. Probably other pro-like gear too. I think a lot of hifi gear is closer to +12 dBu or +13 dBu (i.e. 4V, more-or-less). You would also need to see if that is a "max" output, or a "max at rated" output, meaning that it can do that voltage while maintaining the SINAD or THD+N specs.any full size preamps that do ? or come close?
