I'll try.
System: RME ADI-2 PRO FS, my own MC/line preamp design, VPI classic SE TT with Mijajima Madake cartridge, VPI 3D arm. Modified ML Montis, with the bass path separated from the path to the panels. Raspberry Pi/Volumio, HSU ULS15 Mk ii. 4' long double 12 AWG cable from amps to speakers.
The Rogues have non-stock small signal tubes- selected to make the amps sound right to me, with the input of my spouse, who has a music degree and was trained in voice. An Otari MX50 with various 15IPS tapes was also used.
All of the power amps are mine, except for the Halcro units. The Halcro comparison took place at the home of a friend in Atlanta- he has a DM10/DM68 combo and a pair of stacked quad electrostatics. I brought the RME box and the AHB2s with me. He had an analog only (LP, Tape) system.
The Rogues sounded surprisingly close to the AHB2s- the differences were mainly at the very high end where they were a bit less "bright" and when the music became loud and complex they seemed somewhat congested and the image tended to flatten. The dynamics were also a bit more constrained, they have less of the "make you jump out of your seat in surprise" quality. The noise floor was obviously higher when digital sources were used, but it was not noticeable for tape or LP. The stock tubes sounded less like the AHB2.
The Ncore amps sounded, well, dull, in comparison- softer, less dynamic. It's hard to describe, but it was, apparently, obvious.
I had a friend who unbidden made exactly that observation when I was switching between the amps casually without any prior discussion on the matter. Perhaps the issue is some matching issue with the electrostatics. I tried measuring the frequency response, but I could not find anything unexpected- small signal -3db point at, if I remember correctly, about 50kHz. I can't measure large signal behavior.
I tried both analog and hires digital for sources. The conclusions were the same.
All Amps were initially tested with square waves to ensure stability into the speakers. No oscillation or unexpectedly long settling times were noted.View attachment 39397
Thanks!
That seems like a most excellent setup btw.
Very interesting to read about the ahb2 vs the ncore. I have on some occasions had a similar reaction to class d setups. It’s felt somewhat - well, dull, compared to class ab amps. But that has been sighted listening, so I haven’t put that much stock in my listening impressions. I’ve settled for class ab amps for now, a technology which has been perfected commercially for 50 years.
EdIt: but I’ve also heard some excellent class d speakers/setups, so it might be an amp/speaker interaction thing, or most likely just bias on my side
