All of these measurements are known. But my question was not answered:
Does the AHB2 manufacturer provide any DF data regarding different output levels (or someone has measured it once)?
From my point of view, such data reflect the amplifier behavior in the very dynamic real world, which can be heard very clearly in certain setups. Maybe someone else has this data.
In addition, another axis is basically missing in your presented measurements, i.e. the time axis, in order to show the swing out behavior.
But that would also mean using other test stimulis.
This article does a good job of showing how a DF can act in the real world, as I pointed out earlier. What is so clearly measurable will of course also be perceived. The conclusion of the author within this article is up to you.
DF is another measure of output impedance (OE). Perhaps, EE's can weigh in here but OE clearly varies with frequency not power, at least not significantly. It is simply not discussed. In fact the papers are quite old because the conclusions were QED.
The "proof" image you posted shows the difference between DF of
0.5 and
200 and provides no scale.
Dr. Flyod Toole:
Damping, Damping Factor, and Damn Nonsense (diyaudioprojects.com) (1975)
The image with scale shows the almost no difference (<1 dB by eye) that compared DF of 200, 4, and 1.
No one is denying that DF matters, it is just that it matter up to a point and then it doesn't.
It is load dependent so you will see the point of vanishingly returns stated at 10, 20, 50 and maybe 100 to achive +/- 0.1 dB.
Benchmark chose +/- 0.1 dB as the maximum value that has been shown to be virtually undetectable in ABX tests.
Here is another often quoted article: The
Damping Factor Debate What do the numbers really mean and do very high
amplifier damping factors have any noticeable effect on performance? By
GEORGE L.
AUGSPURGER, James B. Lansing Sound Inc. (1967). Hmm, JBL there is something vaguely familiar about that name
The Damping Factor Debate (diyaudioprojects.com) (1967)
Butler Audio (Text version)
CONCLUSIONS
It should be obvious at this point that the quoted damping factor of an amplifier is important only if the figure lies somewhere below 20 or so. Changing the damping factor from 2 to 20 does change the performance of the loudspeaker system (for better or for worse, depending upon the speaker). But trying to prove that a damping factor of 200 or even more is somehow better than one of 20 is pretty unconvincing because the effective difference in the practical case cited is only that between 1.25 and 1.32.
But someone is bound to insist that exhaustive tests have been made with such and such amplifier and that a very high damping factor is better than one down around 10 or 15. "The bass is just a little cleaner, just a little more natural and open" is the way the argument usually runs.
In a given situation, this may very well be true. Rs is a byproduct of negative feedback. The more such feedback that is thrown into a power amplifier circuit, the lower the generator impedance and the higher the damping factor. The point is simply that if a lot of feedback has to be used to lick the distortion in a particular circuit, fine - use it. But don't believe that the reason it sounds good because of some astronomically high damping factor.
When I get a letter from someone who is worried about buying a certain amplifier because it has a specified damping factor of "only" 15 to 16, I can't help but remember an old, old joke. It goes like this:
A scientist is giving a public lecture. During the course of his speech, he predicts that in 100 billion years human life will become extinct. A man in the audience, obviously upset, asks the lecturer to repeat the statement.
"I said", quotes the professor, "that in one hundred billion years, human life will no longer exist."
"Oh, thank goodness", replies the man, much relieved, "I thought you said one-hundred million!".
Here are some more examples of the practical effects for Damping Factor:
DEFINING "DAMPING FACTOR" by John L. Murphy
Butler Audio
Now if you are concerned about DF and ringing:
- Start analyzing your room acoustics with REW
- Buy better speakers
- Rip out your crossovers, replace them with active crossover and 2 or three amplifiers
I enjoyed reading the papers by Toole and Augspurger now appreciate that the effects of DF have been understood for over 60 years. Some things are timeless.
- Rich
