Revel Salon2 vs Genelec 8351B - Blind Test Preparations
richard12511
But does that mean the preference order will necessarily always stay the same?
When comparing the scores in the Rega vs KEF vs Quad test, the scores of the lowest-ranking speaker (the narrow-pattern, dipolar Quad) improved dramatically in stereo, while the scores of the others did not move much. The score of the Quad did not move up enough for its ranking versus the Rega and KEF to change, and this is what people have focused on as evidence that mono listening preference can reliably be extrapolated to stereo listening preference. However IF the Quads had been compared to other speakers which did not score as high as the Rega and KEF in mono, THEN the ranking easily could have changed.
To me, the more interesting aspect of comparing mono vs stereo scores of the Rega, KEF and Quad is NOT that the ranking stayed the same, but that the Quad's score improved so dramatically. I'm curious about the technical and/or psychoacoustic principle(s) behind this.
This is why I encourage people to look at the actual data, and not just the Harman interpretation of the data. The relative ratings of the speakers changed drastically from mono to stereo, but it wasn't enough to overcome the huge advantage in mono. It's a huge leap from that to say mono to stereo rankings always remain the same.
richard12511
From the research that hs been performed and the subsequent commentary from Toole, yes.
Suggesting that you might be able to create a circumstance which changes this around isn't much evidence of anything. It's speculation.
I've personally created a circumstance which changes this result based on blind testing of a very narrow dispersion speaker and a very wide dispersion speaker. I posted it in my initial reply earlier. I wish I had done a forum thread about it on AVS when I did it. The mono vs stereo vs multichannel results did not hold at all in my case. In fact, they were almost exactly opposite.
That said, I plan to test the mono vs stereo vs multichannel theorem again soon(hopefully after covid), and I'll make a thread about it here asking for advice. For sure participants will be JTR 210, Revel M105, and Infinity R263, but I'd also like to include JBL 308p and Genelec 8030c if I can find a good way to switch between active and passive for cheap.
March Audio
Albany Western Australia
That said, I plan to test the mono vs stereo vs multichannel theorem again soon(hopefully after covid), and I'll make a thread about it here asking for advice. For sure participants will be JTR 210, Revel M105, and Infinity R263, but I'd also like to include JBL 308p if I can find a good way to switch between active and passive for cheap.
Can you describe your test in detail?
March Audio
I don't think you will find that the cited data was the only test they performed. ;)
bigjacko
3. Consider adding a third speaker. Adding a third speaker (ime) makes it harder to identify individual speakers and gives you another reference point, and it's also the recommendation of Harman and Floyd Toole.
I do think if possible adding another speaker would be great so it is harder for people to tell which is which. If people always prefer wider dispersion and that's why salon 2 win subjectively, I would suggest add in kef r3 for narrow reference and bmr philharmonic monitor for wide reference. Those speakers are all flat with smooth directivity, should be good candidates for testing out preference towards wide or narrow directivity.
Duke
Princeton, Texas
A general truth is not necessarily a universal truth. And often a more fine-grained examination of the data is worthwhile.
I am only aware of the one comparison of speaker preference in mono vs stereo (Rega vs KEF vs Quad) where we can see the actual data. Do you know of any others? I'd really like to see them, even if we don't know which speakers were involved.
March Audio
From Toole discussions and he states it in this lecture. No data though.
But let's ask him ;) he does contribute from time to time.
Hi @Floyd Toole. Can you provide some further insight regarding your findings with respect to speaker preference rankings in mono V stereo?
Many thanks
DonH56
Monument, CO
Serious question: Would someone really buy a huge speaker like the Salon2 if they didn't need the bass at all, but used subs anyway?
(Genelec: of course)
Like me, and Dr. Toole, and many others? Here is an old, old post of mine, take for what it's worth. This seems to be another "religious" topic where most are already convinced of their beliefs and no amount of argument will change that.
I use subs, and have for decades, for all the usual reasons:
- Very (perhaps extremely) few "large" speakers actually play well below 40 Hz let alone 20 Hz. They distort heavily when presented with large bass signals (which most are -- see Fletcher-Munson) and driving them down low robs headroom for higher frequencies and causes distortion well above the fundamental signal frequency (harmonic and nasty intermodulation). Subs typically enable the mains to operate with much lower distortion.
- Very rare is the room setup such that the best place for stereo imaging and soundfield is the best place for the subs (or deep bass drivers) to counter room modes and such. Having independent subs provides placement options to smooth the in-room response. It is almost impossible to counter a null without subs (typically must move the MLP or change the room's dimensions though there are purpose-built panels that can also work). This is one of the things that led me to subs despite having quite capable mains.
- Powered subs offload the main amplifiers of the need to provide deep bass energy, providing more headroom and cleaner sound from the amplifiers.
- Music (let alone action movies) often contains deep bass content even if it is not real obvious. Kick drums, tympani, organ, sure, but also piano hammer strikes, plucked strings, beat patterns from instruments playing together, etc. May not really notice when they are there but usually obvious when they are taken away. Having subs fill in the bottom octave or three can make a difference.
- Purpose-built subs can provide high output cleanly at relatively low cost. The amplifiers and drivers need only cover a fairly limited frequency range so have fewer constraints upon them than woofers in a full-range system.
I do prefer main speakers with fairly deep bass and always have. Crossovers are not brick walls so a fair amount of energy still comes from the mains an octave below the crossover frequency. Higher-order crossovers allow you to reduce the overlap, but I still like having the capability. I have never really understood the idea of running "passive" bi-amping as implemented by an AVR (sending full-range signals to multiple channels and letting the speaker's crossovers separate frequency bands -- wastes amplifier headroom and seems to me of little benefit). Nor do I agree with the "plus" setting putting subs and mains in parallel; again, my idea has always been to isolate the two for the reasons above.
My first sub was a DIY design using an Infinity IRS woofer with my own control box to provide the crossover and a servo circuit using the second voice coil of the woofer. I had a Hafler DH-220 around so also incorporated a circuit to bridge it for use as a subwoofer amp. It worked well and the -3 dB point was ~16 Hz. I now run four small (F12) Rythmik subs using a similar (but updated) servo design with my Revel Salon2's and am happy with the result.
FWIWFM/IME/IMO/my 0.000001 cent (microcent) - Don
Stereo subs:
I have gone back and forth on stereo subs over many years (since ~1979/1980 when I built my first sub) and ultimately decided it is not worth it. It limits placement and correction options, almost no stereo content exits at sub frequencies (remember a wavelength is >11 feet at 100 Hz, >22 feet at 50 Hz, just how much stereo separation can there be in a normal listening situation?), and the end result was always much better when I ran the subs mono and placed them optimally for best in-room bass response. If your crossover is so high and/or filter roll-off so low that your subs intrude into the lower midrange you might appreciate stereo but I have always rolled off well below the point at which I could localize the subs. For years I ran stereo subs but many tests blind and otherwise convinced me stereo subs are just an unnecessary hassle that actually reduced my system's performance and sound.
HooStat
Calabasas, CA
Just another variation on the testing -- take your 8351's to @amirm and test both of them and listen to them. Then based on the data and your listening, discuss what you believe the differences to be. It isn't a blind test but it would be a test that could only be done by you guys.
Having said this, I would just do whatever test you want, as well as you can within reason, and share the results. Ignore the critics/hecklers.
richard12511
I gave more details in my initial post. "Ctrl f" for "Personal anecdote" and it should take you right to the start of the tangent. I would repost it here, but I fear may annoy some folks, as it was a long tangent. I can provide a few more details, though. There were 3 people(excluding me) on the first day that took the mono test, and 4 people after that. We had one person tested at a time right in the sweet spot, while the others were in charge of moving. Listeners wore a bandana as a blindfold. Speakers were level matched with pink noise. Switching was done via a switcher, but that was somewhat irrelevant as the time bottleneck was moving the speakers into and out of place. All speakers were crossed over to JTR RS2 subs at 100Hz. Bass was EQed below 200hz with Dirac Live. Listening distance was close to 4m. Listening volume was between 88db and 96db at the listening position. First day was the mono test. Second day was the stereo and multichannel test. That's what I can think of right now, but let me know if you have any other questions.
If you have any suggestions for potential improvements, let me know, as the plan is to do it again soon, but better, and more public. Also, given your experience, if you know of any cheap devices I can use to easily switch between active and passive speakers, that would be very valuable for me. I'd like to include a JBL 308p and a Genelec 8030c(not bought yet) in my next test. I'm no good with DIY.
richard12511
Many thanks
That would be awesome. Imo, the public data we have just isn't enough to definitely say one way or another. The test with the Quad could just as easily be interpreted to suggest that preferences change drastically from mono to stereo.
Duke
Princeton, Texas
Imo the data is everything IF we want to see whether there are things going on which are not covered by the generalization that preference in mono predicts preference in stereo. And I think there are, but of course I can't really make a good case without enough data.
To follow up on March Audio's question above:
@Dr. Toole, do you have readily available any data sets on any mono-testing vs stereo-testing comparisons aside from the Rega vs KEF vs Quad tests? Identity of the speakers need not be revealed, but it would be nice, since what makes the scoring improvements of the Quads so interesting to me is the possible role of their unorthodox radiation pattern.
Thanks!
E
echopraxia
California
Probably very long post incoming. Apologies in advance.
First of all, thank you so much for this. This blind means so, so, so much to me! These have literally been my end game dream music speakers for the past 5 years. I had already somewhat resigned myself to the fact that I'd probably end up having to waste a ton of money by buying both of them to do a blind comparison myself in order to truly be satisfied with my decision. Measurements are great, but blind tests are king for me. I bought my current mains(JTR Reference series) based entirely off blind tests(one that I attended, and one that I read online). There were no measurements at all of the JTRs at the time, but that's how much faith I place in blind tests. Given the price of these speakers, I figured the odds of 1. Someone having both speakers, and 2. Being willing to setup a blind match between them, was basically zero. The fact that you're doing this comparison here has the potential to save me a ton of money if one ends up winning convincingly.
I do have some suggestions based on my past experience with hosting 4 blinds, and attending 1. Hopefully these suggestions don't come across as criticism. I just care deeply about this particular blind, and so there's a lot of passion. Ultimately, only consider the suggestions that you're completely comfortable with, as no matter what you do, I'll be very grateful that you're doing it in the first place.
1. Do not tell the participants ahead of time ahead what speakers are going to be involved in the test. This greatly diminishes the value of the test. This was by far the biggest critique of the M2 vs Salon2 blind that was done on AVS, and many people disregard it completely for this reason.
2. Don't do an ABX text. Do a preference test. ABX is more useful for electronic equipment, but we know for a fact that speakers can sound very different.
3. Consider adding a third speaker. Adding a third speaker (ime) makes it harder to identify individual speakers and gives you another reference point, and it's also the recommendation of Harman and Floyd Toole. Further, if it's a speaker of lesser quality, it might help to differentiate these two beasts some in terms of ratings. For both the stereo and mono tests I hosted of the JTR 212 vs Revel M105, we used an Infinity Beta 20($400/pair when I bought them) as the third speaker. You could maybe add your Sierra towers into the mix? If the Sierras by some chance end up beating the Genelecs, it may shed further light on the mono vs stereo debate. BTW, not saying the Sierras are bad or comparable to the Infinity Betas, but the other 2 speakers are SOTA.
Problems #2 and #3(if not accounted for) combined together can make it very easy to identify the speakers, even under blind conditions. It's part of the reason I no longer participate in the blinds I host with friends. I can easily identify all my speakers. Adding a third speaker and not telling them what speakers are under test makes it almost impossible for anyone(but you) to identify them.
4. Mono vs stereo. I think this is going to be a very hot topic. There's most likely gonna be lots of debate back in forth, and no matter what you choose, half of the people are gonna say your test is useless :(. Do what you think is most logical.
I'll share my plebeian thoughts on the topic based on reading Floyd's book, reading the actual Harman studies, reading great forum threads on AVS, and doing my own mono vs stereo vs multichannel blind listening test at home. My overall knowledge and understanding of these topics is far below many others on this forum.
The Harman view is that mono vs stereo doesn't matter if the sample size is sufficient. The results will be exactly the same, but you'll need a larger sample size with stereo to come to a meaningful conclusion. Imo, this is a valid interpretation of the data represented in the study, but there are also other valid interpretations.
Looking at the study, the Quad's which have very narrow dispersion(and presumably the best imaging) sounded terrible in the mono test, but were very close to the others in the stereo test.
The Harman interpretation that the Quad's improvement from mono to stereo was due to the fact that its flaws were more hidden in stereo. But, another interpretation of that data might be that the Quad's strengths, namely imaging, were absent in the mono comparison. I see no reason why this latter interpretation is any less valid than the former. In my opinion, more research is needed to settle the mono vs stereo debate. Even Toole admits that increasing the number of channels decreases the preference for wide dispersion(don't remember if this was in his book or a forum post).
Personal anecdote on this topic:
As mentioned earlier, one of the first blinds I hosted was a JTR 212 vs Revel M105 vs Infinity Beta 20. This is the only blind where I've ever done a mono vs stereo vs multichannel test, and the results were very enlightening.
In the mono test, the M105 was preferred overall by 3/3 people and preferred on ~80%+ of the tracks. The JTR actually came in last, losing slightly to the Infinity Beta 20.
In the stereo test, the JTR was preferred overall by 3/4 people(we had an extra person after the first day), though admittedly less strongly than the Revel was preferred in mono(I think it was high ~70%, but I don't remember exactly). The JTR also dominated the Infinity in the stereo test.
In the multichannel test, the JTR basically stomped, winning 4/4 overall and only losing 6 times total amongst 104 trials(26 tracks x 4 listeners). It also beat the Infinity Beta 20 104/104 times, and this was in spite of the fact that the center channel was an Infinity Beta C360, and the rear and side surrounds were Infinity Beta 20s. I've since acquired a full JTR surround setup, but this was before, when I just had the front L/R.
Based on these results, I'm fairly confident in saying that the mono vs stereo Harman view doesn't hold for my room. Whether or not that applies to other rooms and speakers, I don't know. As for why it applies in my situation? I don't know for sure, but my current best guess is that it's due to the difference in dispersion width of the speakers. The JTR is +/- 30, and the Revel is +/- 70. I'm not sure what the Infinity is, but I can tell it's closer to the Revel than it is the JTR.
All that said, I don't think the mono vs stereo factor will be as big as a problem for your test as it was for mine. I was comparing a +/- 30 speaker against a +/- 70 speaker. At +/- 60, the 8351b is still a wide dispersion design(the M2 is ~+/-50) in my view. We don't really know the Salon2's horizontal beam width, and we won't until @amirm measures it(side note: I'd be willing to donate money to help @amirm hire movers to move it downstairs and back up), but I would ballpark it in the range of my M105's. So, for you're test, we're probably comparing a +/- 60 dispersion width against a +/- 70-75 dispersion width(and maybe a bit wider if you include the Ascends ;)). I don't think it will be a huge factor in which speaker wins.
If I could get anything I want, I'd want you to do both a mono and a stereo test. Regardless of the results, I think it would be hugely beneficial for audio science. If the same speaker wins both tests, it would add credence to Harman's view that mono vs stereo doesn't change preference. If different speakers win, it would add credence to the notion that more research needs to be done exploring the effects of dispersion width and the relation to the number of channels.
Off topic: I plan to do the mono vs stereo vs multichannel test again(maybe after covid) with my now better knowledge and experience of hosting blinds. I'll probably start a similar thread to this one to ask for advice. The plan is to have the JTR 212 vs Infinity Reference 263 vs Revel M105 vs JBL 308p vs Genelec 8030c, but I still need to find a good way to switch between active and passive speakers.
In order of my personal preference for testing, I would vote:
Mono and Stereo test with subs > Mono test with subs > Mono and stereo test without subs > Stereo test with subs > Mono test without subs > Stereo test without subs.
5. Ask each participant to keep score on a 1-10 scale. We did this for the first blind test I hosted, but stopped doing it after that because it was hard, and the ratings were very inconsistent. I now really regret that we stopped doing it.
6. Have people take notes on what they like/dislike. You did this for your last blind, so I'm guessing you already have this in the plan.
7. Consider again the idea of placing the speakers more optimally. Ideally this would place the Genelec on a stand with the tweeter at ear height at 35" or so, and the Salon2 on the ground with its tweeter at 49"?. Nothing can be done about the Salon2 tweeter being too high(except a long listening distance, which you have). The Genlec though can be optimized better with extra work. Currently you've got the Genelec with a tweeter height of 58"?. Angling it down does help(imo), but it also takes the speaker beam off parallel with your ears, which comes with other disadvantages. Going with what you have I think will be mostly ok, but equal ground would be more optimal. Some may choose not to value the blind because of this. Personally, I don't see it as a huge deal.
FWIW, the two blinds I've hosted with my biggest towers(155lbs), we had 2 guys standing ready to lift the speaker and carry it backwards, and one guy to move the bookshelf + stand into place. We never had very much trouble with that setup. 155lbs in the shape of a tall skinny box is surprisingly light for 2 guys to lift and carry 2ft back. I've also recently been picking up and moving the speaker(about 6ft back) by myself almost every day to give myself more room for playing with my VR headset :D. It's 9lbs heavier than the Salon2, so it can be done, though I admit it's hard(you really have to commit). The way I've found works best is to get behind the speaker, wrap my arms around and grab the front(not on the drivers), bend down to pick up the speaker with mostly my legs and back, then lean back(with it resting against my inclined chest) to walk with it. That said, my speaker has a truck bed finish, so I don't have to worry about damaging(or fingerprinting) the cabinet, so the Salon might present an additional challenge.
It may not be worth it for you, though, and I don't begrudge you for that. Better to do it sub-optimally than not do it all, I say. Above all, I'm still immensely grateful that you're doing this.
8. On EQ. Please, no matter what, don't let people talk you into not EQing below the transition frequency. We know for a fact that below 100Hz, we're not listening to the speakers. Below 100Hz, we're listening to the dimensions and material of the room, and the placement of the transducers within those dimensions. The goal of this test should be to test the speakers themselves, not the speaker placement. If you don't EQ below the transition frequency, you're not testing speaker A vs speaker B, you're testing placement A vs placement B. That latter is still useful, but it's only useful for those who have the exact same room as you(which is probably no one but you).
9. On subwoofers. Please use subwoofers!!! Don't let people talk you out of this. Not using subs would make it a cake walk win for the Salon2 at critical listening levels(especially at 20ft). Given that we know bass is 30% of the battle, it would make the test basically meaningless for those of us who use subs. Whether I end up buying the Salon2 or the 8351b, I'll be crossing them over to 4 JTR Captivator RS2s at 100Hz, so I have zero care for which speaker has better bass. If you don't use subwoofers, you have to do a hard cutoff of everything below 100Hz or so, but even that will be far less useful than how they integrate with subs.
10. If you do decide to do a stereo test, don't do it the way Harman does. Harman, puts the speakers in the exact same spot with the same toe in, and it's the biggest reason why I don't consider the Harman stereo tests as all that valid. This was the way I did my first stereo blind test, but I'm now of the opinion that it's a flawed method of testing. Different speakers in a stereo pair will require different amounts of distances between them, and different amounts of distance from the listener to achieve optimal imaging. The reason Harman does it this way is most likely because they have an automated speaker shuffler and they have to do it this way(designing a more sophisticated shuffler would be much harder and expensive), but it's definitely sub-optimal(imo). Doing it this way has a decent chance of leading to incorrect results.
For example, my M105s sound and measure best about 10.5ft apart, 10.5ft from the listener, and toed in directly on axis. My 212s sound and measure best about 12ft apart, 12ft from the listener, and toed in to cross 3-4 feet in front of the listener. My JBL 308/5ps sound and measure best pretty close to where the Revels do, but aimed straight ahead. If I measure stereo pair A in the position that stereo pair B sounds best, stereo pair B will be at a major advantage. If I measure stereo pair A and B at a random location, the stereo pair with wider dispersion will be at a major advantage, as wide dispersion designs are far more tolerant of positional changes.
In my experience, it takes a solid week's worth of work of moving, listening, and measuring to figure this all out, and given that most people don't do this(including the Harman shuffler), it's a big reason why I much prefer a mono test over a stereo test.
The way we've accounted for this so far is that we'll place colored tape(silver, yellow, purple) on the corner of each speaker top, and 4 pieces of the same colored tape at the base of each speaker to mark its position and toe in. It's easier to show with a picture than it is to explain so I'll post that below.
Using the tape pieces, the 2 speaker movers will move each speaker into the same colored tape position when the switch is called, and the previous speaker will be moved back behind and out of the way.
I very much look forward to your results! Might be fun to start a forum bet beforehand to see where people's opinions lie. I'll throw my own guess into the mix.
I think the Salon2 will win, and I think it will be very similar to the M2 vs Salon2 blind. The M2 has very similar measurements to the 8351b(both are noticeably better than the Salon2), and the Salon2 beat the M2 by 2 points out of ten pretty consistently. The only explanation I can think of is the wider dispersion.
If it's a mono test I'll say Salon2 90% chance
If it's a stereo test, I'll say Salon2 70% chance
PS: You have no idea how jealous I am of the fact that you own both of my dream speakers that I'm trying to decide between.
Wow thank you, this is an extremely helpful post!
All of this makes sense, and I agree with all these good points about procedure. I’m gonna probably let this thread run it’s course a bit and hope that either some consensus comes on a lot of the contentious test procedure points, and if not that’s fine too (I’ll just make my own choices there, but I also agree with your points here).
I was planning to do a blind test in the near term but I think that’s unrealistic as I will want to prepare and give these sorts of discussions time to run their course :)
For now I’m pretty happy with the conclusions from my own sighted test for now (as posted above). As others have said, the dispersion width is certainly dependent on preference, and room.
watchnerd
Seattle Area, USA
Imo the data is everything IF we want to see whether there are things going on which are not covered by the generalization that preference in mono predicts preference in stereo. And I think there are, but of course I can't really a good case without enough data.
Where do we think active, omni-directional beam-steering, DSP-using, but often singular, smart speakers like the Apple Home Pod fit in?
richard12511
I think waiting it out and listening to the discussion is a good plan.
KaiserSoze
Varies immensely by hall.
For Seattle Symphony, in Benaroya Hall, I don't like the closer seats. I get too much violin and not enough everything else.
Plus I don't like seeing the conductor's butt crack.
I believe the part about not liking too much violin.
Duke
Princeton, Texas
Ha! I have no idea.
The beam-steering B&O Beolab 90 speakers apparently sound best in "narrow" mode. Comparisons between the narrow (about 100 degrees), wide (about 180 degrees), and omni modes of the Beolab 90 are about as close to "apples to apples" as I can think of.
Duke
Princeton, Texas
Agreed.
Toole reports Klippel finding spatial quality accounts for 50% of perceived accuracy, and 70% of listener preference. I'm not sure these numbers are precise, but I do not dispute the general message they convey. So I think you are on the right track in considering the Quad's presumably very good spatial qualities in stereo.
Imo there is something else which might come into play, and that is the relative amount of reflections. Apparently we like some, but not too much, reflection energy. As possible evidence of how much we might like, consider that in your tests the medium-width Revels won in single-speaker mode, but the narrow-pattern JTR's won in stereo mode. So it seems to me that two narrow-pattern JTR's may produce a more desirable reflection situation than do two wide-pattern Revels (not sure we can definitively conclude this to be the case).
The Quads probably have an even narrower pattern than the JTRs, so they are probably severely lacking in desirable in-room reflection energy in single-speaker mode, while stereo mode makes them significantly more competitive in that regard.
I am hoping to find data from other comparisons of stereo tests vs mono tests. IF the weakest speaker's score always moves up the most in stereo regardless of speaker design (but never overtakes a speaker which ranked higher in mono), that supports Harman's conclusion. However if there seems to be a correlation between radiation pattern width and how much the score improves in going from mono to stereo, imo that implies something else may be also in play.
