widemediaphotography
- Joined
- Jul 2, 2023
- Messages
- 188
- Likes
- 58
Hi,
I wanted to focus attention on the loopback problems that the USB ports of a common PC are said to be affected by and for this reason there is a tendency, in my opinion, to propose UPnP systems via ethernet because they are galvanically isolated, or to believe that a streamer is better than a PC, because the streamer would also work as a galvanic isolator (In my opinion a streamer is basically a pc). Therefore the questions are these:
1) Is it sufficient to use a split USB cable (data+power), or use a USB cable with the +1 pin disconnected to eliminate any loopback problems of the USB port? If not, why?
2) Does the asynchronous transmission of an audio stream via USB require an analog carrier wave to ensure the transmission of digital data. Is this carrier associated with other current and therefore voltage, even if the DAC is equipped with its own power supply? Could this current create loopback problems?
Thanks
Thanks
