Question about "stereo jack"
daftcombo
Hi,
I need to replace one of the cables (will replace the two, actually) between my phono pre-amp (2 x XLR out) and my Scarlett Focusrite 2i4 2nd Gen (2 x TLR in).
I want to go for cheap but good cables and found these:
https://www.thomann.de/gb/cordial_cfm_15_fv_klinke_xlr_kabel.htm
What puzzles me is the two rings of the jack end. It is stereo, right? What's the point? The other end is XLR so mono.
I cannot find the same kind of cables but with only one ring (mono).
Help!
RayDunzl
Central Scrutinizer
Riverview FL
Unless I am mistaken. the three contact areas on the TRS correspond to the 3 pins in a standard XLR.
One channel, but differential signal and ground.
Bob-23
Berlin, Germany
Both are stereo - two channels, one ground/common (referring to the first ones), btw, cordial, generally good quality
RayDunzl
Central Scrutinizer
Riverview FL
daftcombo
daftcombo
RayDunzl
Central Scrutinizer
Riverview FL
A 1/4" headphone plug is TRS, but unbalanced stereo. Left and Right signals instead of a single differenctial channel.
If there is some gear that expects an unbalanced stereo signal on an XLR jack, it could work as "stereo".
I would just ignore their (presumed) mislabelling in the advertisement.
RayDunzl
Central Scrutinizer
Riverview FL
But why oh why do they advertise it as jack "stereo"?
Same reason a guitar slide could be mistaken for a gudgeon pin(?)
Choose your application, take your pick!
solderdude
The Neitherlands
A TRS plug is also called a stereo jack where the TS plug is also called mono jack.
The cable is designed to be a mono balanced cable.
The cable is not a stereo cable as XLR inputs usually are not stereo.
You could wire an input to be stereo, and perhaps some XLR's can be used that way.
So while the PLUG is stereo the cable is NOT stereo unless you have a non standard XLR input.
Speedskater
Cleveland, Ohio USA
While an XLR connector is always part of a balanced single channel (mono) interconnect system.
a TRS connector (1/4 inch or smaller) may be part of a balanced single channel (mono) interconnect system or part of an unbalanced stereo interconnect system.
If there are TRS connectors at both ends the interconnect system may be single channel or stereo.
The XLR connector is the clue. (it takes two cables for stereo)
sergeauckland
Suffolk UK
It's a pity the 'stereo' jack ever got used for balanced signals when there's a perfectly good jack designed expressedly for balanced signals and which has been around for possibly 100 years.
The B gauge jack is on the left above, compared with the A gauge (normal stereo) jack on the right. Sadly, the B Gauge has never been taken up by consumer equipment and has almost completely disappeared even from professional equipment except for some large installations.
If you have a cable with a B Gauge jack on it, you can pretty much be certain the cable is balanced. With a 'stereo' jack on it, it could be balanced, or it could be stereo.
S.
Rja4000
Liège, Belgium
They don't.
They say 'balanced male Jack'.
And, indeed, the same Jack is also commonly used for unbalanced stereo application. Typically tioconnect headphones to an amp.
Incidentally, they are also commonly used for 'inserts' on small mixers. One 'channel' is then used for 'send' and the other one for 'return', with a Y cable where both legs end with a TS (or 'mono') Jack...
