This got me wondering - what is the maximum possible SINAD of a 990 LDAC connection? 90dB? Above, because there's a 1.8dB disparity between channels, I'm assuming the device is getting in the way.
I could try to measure it using BC3 outputting SPDIF, which can be captured.This got me wondering - what is the maximum possible SINAD of a 990 LDAC connection? 90dB? Above, because there's a 1.8dB disparity between channels, I'm assuming the device is getting in the way.
Would you use 5K's PEQ? If yes, it could make sense.Does it make sense to replace a radsone es100 with the qudelix 5k?
Does it make sense to replace a radsone es100 with the qudelix 5k? I wonder if the music sounds better with the qudelix 5k. I mostly use a koss ksc 75 (60 ohm), venture electronics ve monk plus earbud (60 ohm), Sennheiser momentum 2 on ear (18 ohm i guess...).
The best result for a simple sine wave was THD+N 0.00024 %, which corresponds to SINAD 112. The result depends on the used window and other parameters, so this is not comparable with AP numbers. This used 7-term Blackman-Harris.
Ive just received my Qudeliz and surprised that the max volume is not that much different to the apple usb dongle.
I understand that balanced output will give more power. so what balanced leads to people recommend for Sennheiser HD650?
Ive found the following that I can get to the UK
These are original sennhesier leads with the connections changed, £40 from UK - approx $55.
Drop do one for $50, plus $15 shipping, probably plus 20% tax, so nearly $80
Then there are a number on Aliexpress. Here are four with across a variety of prices. Will there any audible difference between these cables?
$20 inc taxes and shipping - 3.5mm 2.5mm Balanced Pure Silver Plated Earphone Cable For Sennheiser HD580 HD600 HD650 HDxxx HD660S HD58x HD6xx LN006192
$30 inc taxes and shipping - 8 Core Black Balanced Pure Silver Plated Earphone Cable For Sennheiser HD580 HD600 HD650 HDxxx HD660S HD58x HD6xx LN007038
"This is Silver Plated+OCC wire Cord."
$55 inc taxes and shipping - LN006730 XLR Balanced 16 Core 99% 7N OCC Earphone Cable For Sennheiser HD580 HD600 HD650 HDxxx HD660S HD58x HD6xx Headphone
"This is 16 cores 99% Pure 7N OCC Copper Cable."
$82 inc taxes and shipping - Thouliess Hi-Fi 1.8Meter 2.5mmTRRS Balanced 8Croes Silver Plated Headphone Upgrade Cable for HD600 HD650 HD525 545 565 580
"Cable: 8 cores 8x0.72mm (19*0.07mm ) 7N OCC single crystal cooper wire braided divided into"
So have been playing round with the unit and have found that the EQ settings in the HD650 thread (this post) make the output very quiet. Changing the preamp to 0 improves things, and increasing to +5 is too loud for me.
Is the reason for the -8.5dB to avoid distortion when driving the headphones hard?
I did and have not regretted it. My ES100 was perfectly fine but it is now just sitting unused. The PEQ is a fantastic feature on the 5K if you plan on using it. It is a bit of a work in progress but in a good way as they have been constantly adding features (I have had it since launch when PEQ didnt even work yet). LDAC 990 seems to work better on the 5K (usually had to force my ES100 in Developer Options on android and it would stutter...maybe it was just mine but no such issues with the 5K).Does it make sense to replace a radsone es100 with the qudelix 5k? I wonder if the music sounds better with the qudelix 5k. I mostly use a koss ksc 75 (60 ohm), venture electronics ve monk plus earbud (60 ohm), Sennheiser momentum 2 on ear (18 ohm i guess...).
Maybe request it on their official forum if it is important to you? I found them to be pretty responsive.Ps. is there an auto off setting on the Qudelix? Seems a curious absence if there isn’t.
