Proof that speaker cables make a difference
RayDunzl
Central Scrutinizer
Riverview FL
I should have expected a smart ass response like that from you!
It may be appropriate, since I think I originated and described the use of Uh huh on this forum.
https://www.audiosciencereview.com/...a-dac-has-a-sound-signature.9245/#post-240218
Others may have come to use it more often than me, so I had to go ahead and start typing it instead of just thinking it so I wouldn't feel I'd lost my franchise.
PS: I never use emojis.
PPS: The real origin of this particular incarceratium of the term Uh huh! , I will attribute to Thingfish:
[Thing-Fish:]
Just like you! I see some of y'all be FROWNIN'... 'cause mebbe y'think what I's tellin' ya' is a LIE! How 'bout it, folks? Whatcha say? Id dat right?
[Ensemble:]
Yes, it sho' is!
[Thing-Fish:]
Well, les' jes' have a test... how many o' you nice folks think I knows what I's talkin' 'bout? RAISE Y'HAIN UP! Uh-huh!
An' how many thinks my potato been bakin' too long? RAISE YO MIZZABLE HAIN UP! Uh-huh!
Universal Cereal Bus
Transmission line theory is applied to transmission lines at 50Hz and 60Hz. A 6km line will stay charged with reflections for a while. The wavelength at 50Hz is 6000km.
And the wavelength at 20 kHz is 15 km. Are you suggesting your cables are designed for these distances?
I have to admit, that is some big-brain marketing. Basic cable peddlers will only claim improvements in meters of cable, greatly limiting the total amount of cable they can sell to any given sucker. By re-framing the audio shortfall in terms of transmission line theory, you've invented a problem that can only be solved by kilometers-worth of purchases. Bravo!
Mike B
Uh-huh!
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
I know but (and I'm being super picky because this is a much better and more modern forum, especially with the dark mode than many), but being able to "Like" .. "Disagree", "Agree" or "LOL" would save a lot of effort, and non-contributing real estate in threads... Your friends at audiophilstyle nailed it...
I think that could lead to some new people especially feeling gang raped chased away by the ankle biters, even more than they are now.
To me, simple is better in this case.
Consistently supporting positive replies just seems like it works pretty well, but I'm not staking out some position.
Also, sometimes a well timed meme is just the thing...
win
win
Irvine CA
Sealioning: the thread
NTK
US East
They use transformers to match the impedance.
Ah. I see. These are for impedance matching. I always thought they are for stepping up or down the power line voltages. ;)
Helicopter
Michigan
I use emojis to communicate tone to readers who do not read English at the level to infer it, especially with sarcasm. Native English speakers and experts in ESL can probably ignore them. Emojis can be helpful for a significant part of the audience here.
Of course you can just use explicit words, but I like being able to write with tone and then use emojis to translate the tone and make what is already implicit more accessible. :cool:
Chrispy
PNW
At one point I disliked the emojis but learned that they can be a quick and fairly well understood comment....depends on the forum software as to available options I imagine....and some can be bad.
Helicopter
Michigan
It disgusts me when emojis are used as a replacment for words, so I can understand how someone who appreciates words might risk missing their value and utility.
Chrispy
PNW
Am talking about the built - in emojis for basic reactions....not just the like or not option this forum offers....not particularly the use of emojis in general altho am more open to such these days compared to my curmudgeonly beginnings :)
Helicopter
Michigan
Those reaction emojis are fine. I agree with those who said they allow you to react without making the thread 100 pages of redundant posts. I like more options, but the one option here works. I also agree with Woody, we should be careful what we add.
Chrispy
PNW
Without Amir's comments/preferences who knows?
pozz
Слава Україні
Editor
Amir will have the test cables soon. The delay is that he is getting a new set of, 3m current production cables as well so that he can listen. They are being manufactured as I write. Despatch tomorrow.
Thank you very much. I really appreciate that you have stepped forward in this manner.
Max Townshend
A properly functioning high voltage AC power transmission network does not have reflections. The photo that you often post is of a failure mode and like a square wave or step function, the frequency is not 50/60Hz.
When functioning under normal conditions, there are no reflections in mains lines, as there impedance matching.
It is a day-to-day routine all over the world whenever a transmission line idisconnected from the generator and load. After the oil-filled load-carrying circuit breakers have opened, the transmission line is then isolated. The residual multiple reflecting, electromagnetic and capacitive stored energy caused by the open circuit and impedance mismatch results in the fantastic arc that dissipate this stored nergy
The voltage is stepped up or down and the impedance up or down by the square of the voltage ratio.
Lambda
At least for RF frequencies, this is definitely wrong because the reflection is determined at the impedance boundary, so six 50-ohm cables in parallel reflect like six 50-ohm cables in parallel, not a single 8.2 ohm cable.
Of cuase you can put (coax)cabels in parallel to get lower transmission line impedance!
this is commonly done to build quater wave transformer
pZepN91IgpDdDSXC0-SpDLTBmtm-GyupyEmxEkWxeN9S09l6GPTvL5VzQLbA51M4dye1o0dPKMhuyQ0uQE3eWfwlkTPGUOw
