Those people should buy second hand. If you don't have money but want good sound you don't buy new.Making fun of people who can't afford expensive audio equipment? How very audiophile of you.
You stay classy ASR.
Ideal thought, would reversing the polarity on the tweeter help?
Is it cheaper to produce speakers with these odd off-axis characteristics that somehow, somewhat correct on-axis performance? IIRC Audioholics has pointed out similar behavior in some budget Dayton's. Are they really, purposefully producing bad speakers based solely on the assumption Joe Sixpack's going to use them wildly off axis, or is that just a convenient dumb luck excuse?
I stop after I see the Pink Panther. Everything else is just noise.Clearly explained by Amir at the end of his review - you apparently did not read through to the end.
Personally, I wouldn't even trust this type of keyhole mount (below), steel reinforced and screwed keyhole on the back of a Dali Zensor 1. They are too heavy for this long-term, especially in a humid climate.
Lots of buyers would give a 5 star rating because that is the first bookshelf speaker they own and it would still be miles better than the whatever crap they have been using.
Not an expert. But this is imo a poor x-over. I think they just use a capacitor for the tweeter and let the woofer run full. Would be interesting if some x-over mod could be made cheap. So Joe Sixpack could use them better on-axis? What do the experts say?
I bought a pair of these for $55 during a huge sale at Radio Shack back in the day. I briefly tried them on their own as a stereo pair and didn't care for them that way. I then drilled holes in the bottom and hung them upside down from the ceiling (grilles flipped so it looked like I was using them as intended haha) and pointed toward the listening position for rear surrounds in my first home theater setup! They worked well enough for that, and $55/pair was impossible to beat lol.The RS Pro LX5 with linaeum tweeter was measured by stereophile.
https://www.stereophile.com/content/radioshack-optimus-pro-lx5-loudspeaker-measurements
This is with drinking straws damping the port (an essential modification) in the lower trace.
I'm afraid they'll fall down off axis however.
The only problem with the Panther Scale is that the resolution is fairly low. I am not even sure if it is linear or logarithmic -- so I like to look at the data and commentary and work out the correlation.I stop after I see the Pink Panther. Everything else is just noise.
Y'all probably know this, but that's how the world got Viagra. Pfizer was testing a drug for cardiovascular indications, but the test subjects in the clinical trials reported some interesting side-effects. Couldn't find a really good synopsis outside of the peer-reviewed literature (that costs $ or requires,e.g., academic library access credentials to read), but here's an example: http://resources.schoolscience.co.uk/pfizer/viagra/viagch5pg1.htmlI'm going to take a guess and suggest that it could be similar to what drug companies do. You try to make a product that has efficacy in a certain area, yet in your testing, you find it doesn't work as intended. However, you see a 'side effect' that can be monetized, so your time and money wasn't all wasted after all. In some instances, the 'side effect' ends up being more valuable than if the product had worked as initially intended/designed/hoped. lol
Well... if you got lucky, perhaps you could find a pair of these. (For the record, I am still lookin' for a pair).For $70 I would probably buy a set of old Polk monitors... They go cheap and sound good. Probably couldn't hang one on the wall though.
Internet 5 star ratings mean it met expectations, that's all. Anything below a 5 means obviously defective or something wrong with the purchase process. "It arrived on time, it wasn't damaged, I hung it on my wall, it made sound" -> 5. Has nothing to do with being an exemplary product.
It has an inductor on the woofer side. Still, very basic.
That being said, that little 3/4" tweeter needs to cross high. Compare and contrast it to Scott Sehlin's Helium, which also has a 3/4" tweeter. He crosses at 5khz and the C-t-C of the drivers is 2.7" - exactly the wavelength of 5khz, aiding integration. I can't exactly tell what this Polk's c-t-c is but it's at least 5" if not more. 5" is 2.7khz, which means whatever the actual crossover is (somewhere between 3 and 6khz) the drivers are too far apart and you're going to get lobing, just as the spinorama shows. I don't know if a modded crossover can really fix that; you'd have to push the frequency way down and I doubt the tweeter can take it.
What are you talking about? It got straight 11’s.Preference Rating
SCORE: 11.0
SCORE w/ ideal subwoofer: 11.0
No way it scored so high.
