- Joined
- May 26, 2021
- Messages
- 512
- Likes
- 809
Yes, as I mentioned in my last post I realized you were not talking about FR.I have not mentioned a FR error.
I think I will bow out here as I have no idea what “cubic non-linearity” even means.
Amplifiers tend to exhibit a 'quadratic non-linearity' if the circuit is single ended.
It will be cubic if the amplifier is entirely balanced/differential from input to output (this is because even ordered harmonics are cancelled, so distortion compounds less from stage to stage).
Amplifiers that have a single-ended input combined with a push-pull output have both non-linearities. Due to algebraic summing this kind of circuit will exhibit a bit more 5th harmonic.
Feedback suppresses the distortion of these non-linearities. But since too little feedback is used in 99% of amplifiers ever made, the kind of non-linearity that exists will say a lot about how the amplifier 'sounds'. This is simply because the differences you hear between amplifiers, their 'sonic signature' is really their distortion signature. Due to tipping points in the brain, it seems to pay more attention to tonality induced by distortion than it does actual FR errors- unless the FR error is too profound...
Unless you really want to dig into the math of how the amp makes distortion, this might be all you need to know. You can think of any amplifier as the amplifier block being perfect, but also there is a series non-linearity through which the signal must also go.
